nitrobass24
[H]ard|DCer of the Month - December 2009
- Apr 7, 2006
I have configured my ASA 5505 for SSL VPN remote access and have configured split tunneling and its working fine except for DNS resolution for the Secured Tunnel. I can ping the IP addresses of my remote network and can even use RDP to access a box, but DNS resolution will not work and I must use the IPs.
I added Split-DNS for my domain name. What else am I missing?
Below is my configuration.
Code:
: Saved
ASA Version 8.4(1)
hostname HomeFW01
enable password removed encrypted
passwd removed encrypted
names
dns-guard
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan3
no forward interface Vlan1
nameif DMZ
security-level 50
ip address 10.1.1.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
switchport access vlan 3
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa841-k8.bin
no ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network NETWORK_OBJ_192.168.1.96_28
subnet 192.168.1.96 255.255.255.240
access-list Split-Tunnel standard permit 192.168.1.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu DMZ 1500
ip local pool IPBR_RA_Addresses 192.168.1.101-192.168.1.110 mask 255.255.255.0
ip verify reverse-path interface outside
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-641.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source static any any destination static NETWORK_OBJ_192.168.1.96_28 NETWORK_OBJ_192.168.1.96_28
nat (inside,outside) dynamic interface
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa local authentication attempts max-fail 3
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 5
ssh version 2
console timeout 0
management-access inside
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.33 inside
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable outside
anyconnect image disk0:/anyconnect-win-2.3.0254-k9.pkg 1
anyconnect enable
tunnel-group-list enable
group-policy GroupPolicy_Anyconnect internal
group-policy GroupPolicy_Anyconnect attributes
vpn-tunnel-protocol ssl-client
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Split-Tunnel
default-domain value davis.local
split-dns value davis.local
address-pools value IPBR_RA_Addresses
webvpn
anyconnect keep-installer installed
anyconnect ssl rekey time 30
anyconnect ssl rekey method ssl
anyconnect ssl compression deflate
anyconnect ask none default anyconnect
username removed password removed encrypted
tunnel-group Anyconnect type remote-access
tunnel-group Anyconnect general-attributes
address-pool IPBR_RA_Addresses
default-group-policy GroupPolicy_Anyconnect
tunnel-group Anyconnect webvpn-attributes
group-alias Anyconnect enable
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:d6d17e14a24cbfd38197bb3723f324ca
: end
