Okay I just loaded up speedfan and it is showing me 3 temps
Temp 1 : 35C
Temp 2 : 22C
Temp 3 : 56C
Now what in the world is Temp 3?
I loaded up core temp and orthos for about 2 hours and the CPU Temps were around 50C
Asus Prob put my CPU Temp at around 37C, MB Temp around 35C underload
So Im a little confused at where this temp is located at.
Any help would be appreciated.
I just got off the phone with asus tech and they said that it was an erroneous reading (apologies if I mispelled that word) and that if I am not experiencing stability issues and such, it is okay. They said I should just check the MB temp in BIOS and that would be the most accurate indicator, I could get of the temp sensors.
What is your guys opinion on this?
Temp 1 : 35C
Temp 2 : 22C
Temp 3 : 56C
