Jeffredo
- Aug 30, 2008
I've accumulated enough old parts to assemble a PC from, more as a "hobby" project than actual need. I have three ideas for the OS. First the hardware:
Athlon 64 X2 6400+
AM2+ Motherboard
4GB of DDR2 800 RAM
128GB SSD
Definitely not going to set the world on fire, but it would be fine for a backup PC for browsing or playing old games. My OS choices are Windows 7 OEM for about $80 (Newegg often has it on sale for that). Only bad thing is that its tied to that one hardware setup and since the hardware is pretty old that might not be a wise choice. Second choice is Windows 8.1 full version for $107.00. That I can moved from PC to PC. Third choice is a dual boot with Windows XP and a Linux distro. I can keep the XP side offline after April. That choice would cost me nothing (and give me a chance to learn something about Linux). What would you do? Also, if I keep the XP side of a dual boot without a network connection, would it still be vulnerable if I have the PC hooked up to the internet (for the Linux side)?
Athlon 64 X2 6400+
AM2+ Motherboard
4GB of DDR2 800 RAM
128GB SSD
