I need software that allows you to record sound from when your playing the radio on the internet
I had a really simple one on XP, which just had record and then a little media player and you could also edit the file by taking time off the end and front
So basically i need:
an audio recording software
and a software which will allow me to chop the start and ends of what ive recorded
Thanks
Mayhs
Thanks
Mayhs
