Syphon Filter
- Dec 19, 2003
Guys,
I'm looking for a little advice about these two cards.
I have a bog-standard Z (retail version) on order for £58 (only £10 more than the OEM so I figured why not).
I will be using this with a set of BeyerDynamic DT880 250 Ohm headphones.
However, I have recently noted that the Z (and ZX) do not have selectable gain settings. Only the ZXR does. I am hoping this is not an issue as I believe the gain options are just Low (32-300Ohm) and High (600Ohm) but I am doubting my choice somewhat.
The price difference between the Z and the ZXR is over £100 but I'd rather buy right first time rather than deal with issues/returns. I would not really be using the extra features of the ZXR such as the add-on card and the control module, these would just collect dust. The only thing about the ZXR that is attractive are the different (improved?) DAC and amp but £100 seems a little for that (to me).
Can anyone give me some real-world experiences of using the standard Z card with a decent set of cans?
What do you guys think, stick with the standard Z (saving a few quid) or sack it off and go with the ZXR?
