Sony Confirms PlayStation 4 Successor
Discussion in 'HardForum Tech News' started by AlphaAtlas, Oct 9, 2018.
  1. AlphaAtlas
    AlphaAtlas [H]ard|Gawd Staff Member
    1,716
    Mar 3, 2018
    Plenty of Playstation 5 rumors have been swirling around, but they're all just rumors. However, Sony's CEO Kenichiro Yoshida recently told the Financial Times that "At this point, what I can say is it’s necessary to have a next-generation hardware." While the next gen console wasn't named, the Times's sources also mentioned that the new device "might not represent a major departure from the PS4, and that the fundamental architecture would be similar." Previous rumors suggest that AMD designed Navi with the PS5 in mind, which makes that claim particularly interesting.
    Microsoft’s Phil Spencer did reveal that Xbox was currently “architecting” its next generation consoles at E3 2018, however the reveal was similarly cryptic. Once again, the two rivals seem to be treading a similar path, as Microsoft’s Project xCloud gaming service hopes to reinvent how video game streaming works to a variety of devices.
    Kinsaras likes this.
  2. Armenius
    Armenius I Drive Myself to the [H]ospital
    16,234
    Jan 28, 2014
    So the rumors about "backward compatibility" with PS4 may be true in that case, if the architecture is the same with just an updated SOC under the hood. The console industry may very well be moving to the cell phone industry's strategy of incremental updates from here on out.
  3. exlink
    exlink [H]ardness Supreme
    4,106
    Dec 16, 2006
    *shocker*
    Ironchef3500 likes this.
  4. Rahh
    Rahh [H]ard|Gawd
    1,618
    Jan 14, 2005
    So, milk it till people stop buying concept. Got it!
    Madmeerkat55 likes this.
  5. gamerk2
    gamerk2 [H]ard|Gawd
    1,534
    Jul 9, 2012
    Which isn't surprising; consoles are just low end PCs running stripped down OSes at this point anyway. Also remember there really wasn't a CPU upgrade this generation; the CPU in the PS4/XB1 is about the same as the XB360's CPU, and weaker then the Cell by a significant amount. And surprise, it's the CPU holding this generation back; 4k really wasn't in mind when this generation's specs were laid out.
  6. Armenius
    16,234
    Jan 28, 2014
    Hardly. The CPU in the Xbox 360 was a tricore PowerPC. Completely different architecture, though I agree that as far as performance goes they are very similar (115 GFLOP/s in the Xbox 360 vs. 102 in the Playstation 4). Could say it was a downgrade on the CPU side of things. Both Sony and Microsoft made the mistake in believing that a more powerful GPU would make up for the weaker CPU.
    Patton187 likes this.
  7. Domingo
    Domingo Skip My Posts
    16,716
    Jul 30, 2004
    Let me guess, they're going to target real 4K at 30fps. It's not like they're going to be able to target 60fps and 1080p isn't marketable anymore.
    With the mid-life upgrades it's getting harder and harder to care about new consoles.
    Armenius and LightsOut41 like this.
  8. Burticus
    Burticus 2[H]4U
    3,745
    Nov 7, 2005
    PS 4 super-pro? Mega-pro?
    Armenius likes this.
  9. N4CR
    N4CR 2[H]4U
    3,431
    Oct 17, 2011
    What do you think Polaris 12nm is for?
    My bets are on a 12nm PS4, bit like the pro but even less of a bump.
  10. Darunion
    Darunion 2[H]4U
    3,679
    Oct 6, 2010
    8K downsampled to 4K 60fps (interlaced frames to provide a fluid seamless gameplay superior to pc gaming) to provide a much sharper image than just 'normal 4k' could produce.
    Probably should put AI or Quantum in there too for wow sprinkles
  11. VIC-20
    VIC-20 Gawd
    838
    Mar 24, 2006
    PS 4 Pro 2 Go Portable VR Slim Vita Edition - Memory Card Pro Duo not included.
  12. OnceOver
    OnceOver n00b
    32
    Apr 10, 2017
    Hope it has a 4K Blu-ray player. The PS4 Pro should've had one. If it can't do solid 4K gaming I don't see the point of another Playstation.
  13. homernoy
    homernoy Limp Gawd
    452
    Jan 31, 2007
    I'm done buying consoles for myself, I've become a PC gamer the vast majority of the time. My son will probably want new console hardware, but if the past is anything to go by, he always wants to play games on my PC. He has PSVR, but always bugs me to play my Vive.
    Why don't you buy an Xbox One S? I've been thinking about it mainly because it's relatively cheap, but in my case, my son already has an Xbox One (and vanilla PS4), so I'm going to hold off.
  14. Chris_B
    Chris_B [H]ardness Supreme
    5,053
    May 29, 2001
    A new console you say? After ps1,2,3,4 and pro i would never have guessed that "5" would be an eventuality. :unsure:
    wrangler likes this.
  15. [21CW]killerofall
    [21CW]killerofall Aliens...
    2,777
    Mar 16, 2006
    Other possible names are just "PlayStation" with no number or "PlayStation X" but will Sony have the courage to do this?
    /s (only slightly)
  16. Red Falcon
    Red Falcon [H]ardForum Junkie
    9,821
    May 7, 2007
    I think you might be basing those GFLOPS ratings on the GPU in the 360 rather than the CPU - the tri-core PowerPC Xenon CPU should get around ~75 GFLOPS (each core is a derivative of the PPE in the Cell CPU, which itself was capable of around ~25 GFLOPS by itself).
    The 8-core AMD Jaguar @ 1.6GHz in the PS4 gets around roughly ~102 GFLOPS.
    Integer performance is far greater in the Jaguar CPUs on the current-gen consoles, though, by quite a large margin.
    I would imagine, to make up for the loss of the FPU performance on the Jaguar CPU, that most of that task has been off-loaded to the AMD GPUs in the current-gen consoles; the last-gen consoles' GPUs were not capable of FPU-based tasks, as they were both the generation literally right before the unified architecture was released by both AMD/ATI (at the time) and NVIDIA.
    I will agree with you to an extent on this, as the CPU in the current-gen consoles is literally the one thing holding it back from most newer AAA games from reaching beyond 30fps, regardless of the resolution - the CPU just cannot keep the GPU fed information properly, resulting in less than 60fps, even though the GPUs on the higher-end consoles are clearly capable of 60fps+.
    This obviously doesn't apply to every game out there, though, as less CPU-demanding games and 2D games can easily run at 60fps with native 4K resolutions - really depends on the game and the needs/requirements of the game engine itself.
    Take the new Spider-Man game just released, for example, regardless of resolution and console (original/Slim/Pro), the game will always run at 30fps.
    Even on the Pro, Spider-Man does have clearly visible graphical improvements, yet still runs at 30fps.
    Both Sony and Microsoft are well aware of this, as are a majority of the AAA devs out there, but there just isn't anything further that can be done to improve this, other than clocking the CPU much higher, which for the form factor and power envelope (not to mention the PSU) of the consoles just won't allow.
    So, time for a new console generation with (hopefully) a much more powerful CPU.
    Even if they don't use an 8-core CPU, it will most certainly be at least a quad-core with SMT to allow for a minimum of 8 threads.
    GoldenTiger and Flogger23m like this.
  17. gamerk2
    gamerk2 [H]ard|Gawd
    1,534
    Jul 9, 2012
    The 360's main CPU across all cores top out at about 105 GFLOPS. The Cell topped out around 240 GFLOPS, though due to programming difficulties around 170-180 GFLOPS was more typical [the Cell was and is a beast]. The real problems were keeping the CPUs adequately fed with data.
    GPUs were the huge increase this generation; the PS3 GPU could handle around 190 GFLOPS and the 360s around 240 GLOPS. Meanwhile, both the PS4 and XB1 can easily push over 1500 (XB1) and 1900 (PS4) GFLOPS.
    Not sure where you're getting your numbers from.
    Red Falcon and Armenius like this.
  18. Flexion
    Flexion [H]ard|Gawd
    1,576
    Jul 20, 2004
    I hope they finally work towards 4K 60Hz (60fps, etc.) playable on TVs via console. Sony has had 120Hz native input support for 1080p for a couple years already (though they only got rid of weird artifacts about a year ago.) Samsung finally put 120Hz native input support on their most recent models. While I'll always have a high end PC for gaming sometimes it's cool to just chill on the couch playing console. (I know I know... Just build a PC for the living room TV and use a controller.)
    30fps is just painful to look at after playing on PC. XD
  19. Comixbooks
    Comixbooks Ignore Me
    12,355
    Jun 7, 2008
    So you bought a PS4 for exclusives so did I but I sold mine 2 months ago to two grungy kids hanging out at Gamestop.
    Gamestop said my PS4 was defective so they wouldn't buy it for me. So I drove the grungy boy men to the local ATM and got 150.00 for it.
    Right now I'm using my PS3 as a DVD player :D If the PS3 DVD player fails I have a PS2 DVD player for a backup :D
    PS5 I would'nt touch it with a ten yard stick due to lack of studios and development besides Rockstar, Gorilla Games and Sony it'self. Basically the only PlayStation console that made me feel good about owning one was the PS3 the PS1 comes in a close second due to games like Jumping Flash and Kings Field and shooters like G-Darius and Einhander.
  20. Red Falcon
    9,821
    May 7, 2007
    Before going any further, when I talk about "GFLOPS", I mean FP32 single-precision FLOPS, just FYI so there is no confusion. :)
    That's very interesting, those cores must be clocked much higher than the PPE is, or have additional functions or features to have that much processing power.
    I'm definitely not saying you are wrong or anything, but I am wondering how you are getting that number? (legitimately would like to know)
    The PowerPC-based Xenon tri-core CPU @ 3.2GHz should be capable, according to the clock speeds and extreme similarities to the PPE in the Cell, should have around ~75 GFLOPS of computational processing power.
    The reason I am stating this is because the PPE, by itself, in the Cell is capable of 25 GFLOPS - multiply this by three at a similar clock speed and it should be around ~75 GFLOPS, especially since both the SPE in the Cell and the three cores in the Xenon are all clocked at 3.2GHz, making for a fairly direct comparison.
    Would you happen to have a source for your information on that 105 GFLOPS number by any chance?
    Again, I would legitimately like to know as I was not able to find a solid source for it myself.
    Well, the PPE unit in the PowerPC-based Cell @ 3.2GHz had 25 GFLOPS on its own, and each SPE unit had 25 GFLOPS as well - so with the 1 PPE unit and the 8 SPE units, the total should be around ~225 GFLOPS, so if the Cell was clocked a bit higher (assuming optimal performance and optimization like you stated) then your 240 GFLOPS number wouldn't be too far off, if at all.
    Mind you, I'm talking about the original vanilla Cell, not the PowerXCell 8i CPU.
    In the PS3, one SPE was disabled for better yields from IBM, and one SPE was dedicated to the OS or hypervisor, leaving the Cell in the PS3 with 1 PPE unit and 6 SPE units, for around 150-175 GFLOPS, generally speaking.
    I will agree with the, and the higher-end consoles have around 5-6 TFLOPS in the GPUs as well.
    Hopefully what I had written out above helped to explain where my numbers were coming from.
    If those number are incorrect, though, I actually would like to know, and if you do have any sources to back your info, please share it as I really would appreciate it, thanks! (y)
  21. SecretStash
    SecretStash Limp Gawd
    469
    May 27, 2017
    As a PC gamer I say, "good". More motivation for Bethesda to get back to work on TES6 since they were "waiting for the technology"
  22. gamerk2
    gamerk2 [H]ard|Gawd
    1,534
    Jul 9, 2012
    Wikipedia is fun:
    https://en.wikipedia.org/wiki/Xbox_360_technical_specifications
    https://en.wikipedia.org/wiki/PlayStation_3_technical_specifications
    A number of other sources also confirm the numbers. Comparing to the PS4/XB1:
    https://en.wikipedia.org/wiki/PlayStation_4_technical_specifications
    (No Wiki page for the XB1 Technical Specifications? For Shame Wikipedia!)
    Regardless, we do have the PS4/PS4 Pro numbers which give the CPU at 102/134 GFLOPS (compared to the PS3's 230 GFLOPS). The GPUs are beasts though; 1800/4200 (!!) GFLOPS, which puts the 192 GFLOPS in the PS3 to shame. XB1 is likely in the same ballpark.
    Red Falcon likes this.
  23. SeymourGore
    SeymourGore 2[H]4U
    2,638
    Dec 12, 2008
    Personally I'm okay with a new generation, always felt that the PS3/X360 era was a little long in the tooth. B/C would be a huge plus and probably would get me to upgrade sooner than later (especially since I'm picking up a Pro for Red Dead 2 later this month).
    I'm hoping the target will be 60fps standard (checkerboard 4k is okay by me).
  24. Red Falcon
    9,821
    May 7, 2007
    You know, I have no clue how I missed all of that very obvious information on Wiki... :whistle:
    You are right about the 8-core Jaguar having ~102-134 GFLOPS - don't know how my math was so very off on that, so I have gone back to try and fix earlier posts with incorrect information.
    Thanks man, you rock! (y)
