Oct 28, 2006 #1 O OuTLaWzSm Limp Gawd Joined Sep 26, 2004 Messages 204 Title says it all. Need a good one. To hide my IP and continually change it correct? I can't find a proxy software, all the ones I used don't work. Thanks for helping.
Oct 28, 2006 #2 E eeyrjmr [H]ardness Supreme Joined Apr 23, 2002 Messages 4,363 a rpoxy is like a portal that all data goes through you don't install s/w on yr machine unless you want to act as a portal or you want to use TOR just search google for a proxy list and choose one and enter the IP/# into the proxy settings of Firefox
Oct 29, 2006 #3 D Deleted member 143938 Guest Proxy masks your IP address to websites and such, but is easily seen through, it also slows down your connection a lot. It makes you connect THROUGH that IP address, so inturn it has to travel from that IP to the destination IP
