I'm hoping to finish my basement once spring rolls around, and I figured if I'm ever gonna run ethernet lines in the house, it's probably my last chance. So I'm just trying to draw a few pointer from experiences some of you have.
I ran wired network in my previous residence, so I have all the hardware and ideas on what to do with them, But I've never installed wires behind walls, so I could use some pointers.
I'll run all wires to the basement where I'll house all my servers and networking gears. As I mentioned, the basement is still unfinished, so wiring the first floor seems simple enough. Just drill through bottom plates of the framing and subfloor panel between joists, no?
2nd floor is a bit tricky, but it looks like there might be some extra cavity next to return air duct. Not sure how much wood I'm going to have to drill through between floors though. Is it just bottom plate+subfloor+top plate or is there something else? Also How big of a hole can I make with out weakening the frame? I'm going to need to run at least 6 wires to 2nd floor, maybe it'd be better to make 2 holes? And I was wondering how hard would it be to run a cable along the outer walls with insulation? Would that be just impractical without opening up the drywall?
Also, I have a full sized rack cabinet that's going to house all my equipment in basement. I'm debating using patch panels or a bunch of regular wall plates to run the cables to the cabinet. If I can flush mount the patch panel into the drywall, I think I'd prefer that, but I'm not sure if I can?
Thanks for all the help. Any other advice in running cables in the walls would be greatly appreciated.
