I'm in the market for a new router and I've been thinking about building a m0n0wall box. How does it compare to something like this? Specifically, that router has 3 antennas, doesn't this mean it has better coverage than an old PC-turned-router with only 1? Can any old NIC just broadcast a wireless signal? As for the two NICs requirement, will the onboard NIC built into the motherboard work for one of them, or do you need two dedicated NICs?
Also, if I download an IP blocklist using Blocklist Manager, can I export it into m0n0wall and have it block a range of IPs? specifically I would be looking at the malware, adware, and bogons blocklists.
