Found a review.
Translated from German so it's a little weird to read.
http://translate.google.com/transla...intel-dg45fc-review&hl=en&ie=UTF8&sl=de&tl=en
For bonus points, you can use something like Sil-Pads, which is like electrical tape made out of Arctic Silver 5. You can get these or similar products from electronics shops. Those voltage regulators may get hot, in which case, you can use your case as a crude heatsinkThis time around I am going to cover the motherboard mountplate in electrical tape so I won't kill the next one.![]()
Isn't arctic silver 5 conductive? That would negate the purpose of isolating the motherboard plate if that was the case. I have always heard the that arctic silver 5 is conductive. So i assume in tape form it would be also.
It's like AS5. It's in fact electrically non-conductive, the only thing it conducts is heat.Isn't arctic silver 5 conductive? That would negate the purpose of isolating the motherboard plate if that was the case. I have always heard the that arctic silver 5 is conductive. So i assume in tape form it would be also.
(In hindsight it was a lousy analogy.)
So let me get this straight I should rather than use electrical/duct tape, masking tape use this "thermal interface tape" to isolate the motherboard back plate? I don't even know if the components generate that much heat. All I thought I needed to do was prevent the shorting out against the back plate.
Where can I get this fancy non electrically conducting thermal interface tape?
