some icons not showing
Discussion in 'Operating Systems' started by fightingfi, May 10, 2016.
  1. fightingfi
    fightingfi Look at Me! I need the attention.
    2,443
    Oct 9, 2008
    i can see my kaspersky icon running which is but not steam and others how do i enable the others plz thanks :) windows 10 pro 64 bit
  2. Comixbooks
    Comixbooks Ignore Me
    12,633
    Jun 7, 2008
    You have two monitors?
  3. fightingfi
    2,443
    Oct 9, 2008
  4. Violator
    Violator Gawd
    706
    Mar 31, 2005
    Are you talking about on the desktop or the task bar?
  5. fightingfi
    2,443
    Oct 9, 2008
    where the clock is in the right hand corner and the time and date
  6. Violator
    Violator Gawd
    706
    Mar 31, 2005
    Right click where the notification tab is and you should get a group of icons pop up (stuff you've installed), just drag them down to the notification area (bit just to the left of the clock)
    primetime likes this.
  7. primetime
    primetime [H]ardness Supreme
    5,493
    Aug 17, 2005
    good tip lol...i been doing it the hard way in the settings
