Azrak
- Oct 4, 2015
tl-dr: I cannot set DRAM voltage. It stays at 1.200V no matter what I do. This prevents DDR4-3200 operation.
Built a new system today.
2700X
G.Skill Flare X 3200C14 2x8GB kit
Seasonic Prime Ultra Titanium 850W
Board came with 0401 BIOS.
Immediately flashed to 0601.
Try #1:
Set AI Overclock tuner to D.O.C.P. Standard which loaded the 3200 profile from the memory.
This set BClk to 100.0, DRAM speed to 3200, DRAM voltage to 1.3500, timings to 14 14 14 34.
F10 to save, reboot back into BIOS and speed is 2400, voltage is 1.20V.
Confirmed with HWiNFO in Win10.
Try #2:
F5 to reset to defaults. F10 to save and reboot back into BIOS.
Set AI Overclock tuner to Manual.
Set BClk to 100.0, DRAM speed to 3200, DRAM voltage to 1.3500, timings to 14 14 14 34.
Flashed from 0601 to 0509 (latest official), same thing.
Flashed back to 0601 again. Same thing.
The fastest speed I can get is 2866 on 1.20V. 2933 causes it to revert back to 2400. No kidding, I need 1.35V to get to 3200 speed.
What am I missing/forgetting to do or is this MB bad?
2700X
Try #1:
Try #2:
