Originally posted by gee
I swear by my Hakko 936 ESD workstation, but it's a little pricy for anyone just starting out in electronics.
Anyhow, I'm fond of the 15/30 watt selectable iron that Radio Shack has. At 15 watts, it's perfect for fine soldering, and at 30W it's perfect for soldering large contacts and desoldering things.
If you've got money to burn or are seriously considering electronics as a long term hobby, then definitely get a temperature controlled soldering station. The difference between one of these and a regular 'always-on' pencil iron is night and day...
edit: I also own a Weller 100/150W gun, which I use for desoldering very large items and other things that need brute force. Beyond that, the gun sits on the shelf... most guns produce far too much heat to be useful for any kind of 'practical' soldering.
I own a Portasol torch, and I hardly ever use it... I find the soldering iron tip gets way too hot - if you leave it going long enough, the tip eventually glows red! I found I was constantly touching the tip to a wet soldering sponge to cool it down before I used it. Also, I find it too big and awkward to use precisely. I certainly wouldn't do SMT stuff with it...Originally posted by litkaj
I've got 8 (yes, 8) of those 15W/30W Radio Shack irons, they're pure crap. I bought my Weller Portasol PSI-100 a year ago and I'll never go back to an electric iron, especially not from Radio Shack. Plus, it's useful when making Creme Brulee since I don't own a culinary torch...
But for soldering heavy stuff, the heat output of the thing was amazing. I still use it for things like car wiring, where you want heat and aren't concerned about precision.
IMO, there's nothing better than a good temperature-controlled soldering station. Temperature is important; too high and the flux burns up right away and you get a crappy joint, too low and you get a cold solder joint.
What the world needs is a temperature-controlled soldering station that runs off propane
I've got one of the first Portasol irons that Weller put out. I don't even think it has a model number, it's a blue iron with "portasol" written on the side and nothing else.Originally posted by litkaj
Which Portasol do you have? Mine never does that. I just did a quick test. I filled it up, turned the temp up as far as it goes and lit it up. After letting it run for 40 minutes without doing anything it looked perfectly normal, no glowing at all. Maybe yours was defective...
Also, I don't think that the PSI-100 is very large at all. It's about the same size as the crappy Radio Shack 15/30 irons. Plus, the neck is shorter than a normal iron so my soldering is much more accurate.
Could be defective, or it could just be the first product they put out. We recently won a decent amount of money in an office lottery pool, maybe I'll treat myself to a new iron..
