Is there a program that will do this? As far as I can tell FRAPS only queries once a second. I want a program that queries at least every 1/10 of second.
I am trying to illustrate the stutter that Black Ops is experiencing. An average of 60fps isn't playable if the first half of a second you get 0fps and the other half of the second you get 120fps. It numerically averages to 60fps but you still have a frozen screen for half a second at a time which makes it unplayable if it keeps happening. It's a matter of smoothness.
Of course the stutter is a little more complicated than that so it would be helpful to visualize frame rate numbers on at least a 1/10 second scale. A 1/60 second scale would be even better. So anyone know software that will do this?
