Nuc_E said:Socket 754 and XP don't go in the same sentence together.
buzzly said:XP-M is a socket A cpu, not socket 754. Which one is it? Why don't do spell out the CPU code here? Make it easy for people to help you.
freshmtb said:It's a socket 754 XP-M.Check the bottom of the page on the link you posted,XP-M in black and white.
kirbyrj said:Why in the world would they fit XP chips onto s754? They are incompatible due to the memory controller being on die (s754) vs. on board (socket A). So they would essentially have to make a special motherboard to run their special chips. Makes no sense.
freshmtb said:Ahn2800bix2ax
freshmtb said:Look like you have a early core,-ver DH7-CG, higher power consumption @ 1.4v, Sempron.
