PaperclipGod
- Dec 31, 2011
...built in 2003. Yes, my rig is nearly 10 years old.
So, please help me build something new.
Gaming, browsing (often with 50+ tabs), limited CAD stuff (inventor, architect, etc)
$1000, but my priority is "most bang for the buck". I'd be quite happy to spend less!
Springfield, MA. I'm 1.5-2 hours west of the Boston Microcenter, so unless the deal is outrageous, it probably isnt worth the gas.
CPU (thinking 2500k)
CPU heatsink
RAM (thinking 8gb, but 16 is appealing)
Mobo
HDD
GPU
PS
OS (Win7 home vs. pro?)
Case (old coolermaster praetorian)
Monitor (mitsu 2070sb)
Keyboard/Mouse
Klipsch 2.1's
Yes
Mitsubishi 2070sb
22" tube, 20" viewable
2048x1536 max
Within the next day or two, unless i get advice otherwise
I'm not sure. USB3 would be nice, as would SATA6, but neither are dealbreakers. Do current hdd's even make use of sata6?
No, need an OS. If not for games i'd use linux. I'm not sure if i'm better off with Win7 Home or Pro, though. The main difference seems to be in the amount of ram supported?
CPU heatsink
Mobo
HDD
GPU
PS
Keyboard/Mouse
Klipsch 2.1's
6) Will you be overclocking?
Yes
Mitsubishi 2070sb
2048x1536 max
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
