From what I understand those are not guaranteed to hit their overclock with out issue.Those gsync monitors that advertise as overclockable make it seem more like a marketing buzzword than an actual overclock. If the monitor is guaranteed to actually support that signal natively it isn't an overclock IMO. There is nothing to worry about when using the higher refresh rates.
There are monitors that can actually be overclocked to higher refresh rates than they support by manually adding a custom resolution. And there really isn't any risk in doing that. The monitor typically just accepts the signal or doesn't. If it does accept the signal sometimes it will have frame skipping where it is basically just ignores the extra frames instead of displaying them. So you may think you have a working overclock but really don't. I've never heard of anyone damaging a monitor through overclocking though.
