Gorankar
- Jul 19, 2000
Would he really need a box fan to cool a 5850? Didn't think so.
man this gives me some ideas for a couple of parts i have laying around. I wonder if i could rig up my thermaltake 250 W pure power express (5.25 bay video card power supply) with my X1900XT thats collecting dust to my vostro 1400. I'll have to figure out if the purepower can be made to work without being hooked up to a regular power supply. I could probably squeeze the card and PS into an enclosure that would maybe fit in my laptop bag.
Awesome find OP
That's from the manufacturer's website under specifications. Only 1 PCI-E power connector? Buy one of those and tell me how well it works with a 5850.
lloose said:ViDock 4 Plus adds a second 2 x 3 pin power connector to accommodate graphics cards that require up to 225W.
That won't work, the HD5850 requires one 8-pin and one 6-pin PCIe Auxiliary power connector. Using that adapter might blow up the small dedicated power supply in the ViDock if it can't handle anything much more than the rated 225w of power draw.
That still makes it an 8-pin adapter. Optional or not, 6 plus 2 equals 8. Newegg even notes as much in the item description.I did not post a 6 pin to 8 pin adaptor, I posted a 6 pin to a dual 6+2 pin adaptor. The "+2" is break away, you can use it or not use it, it doesn't matter.
We're limited to a PCIe 1x link here. The more RAM on the video card, the better. This was discussed at-length earlier in the thread. If you were going to use an HD5870, the 2GB model would be the one you'd want to use for optimal performance with this kind of setup.Other than the 2GB models, all the 5870's I've seen are using 2 6-pin connectors
The 5870 uses 188watts at full tilt, still well under the 225watts. The H review is stating total system power consumption, not the video card alone.
Again, why would you want an overpriced ViDock? Even if it does work, you're spending a LOT of extra money over the DIY solution, and all you get for it is a metal box to go around the card (which restricts your heatsink choices, no less).Again, it will work flawlessly.
Are you sure? They seemed quite clear when they said "The PCS+ HD5850 drew 388 Watts at load"
Again, why would you want an overpriced ViDock? Even if it does work, you're spending a LOT of extra money over the DIY solution, and all you get for it is a metal box to go around the card.
Why do people want pc cases? I mean, just having the shit laying around your desk is a good way to save money.
I did not say you should leave the parts lying around. On the contrary, I already posted a link to some $5 project boxes from RadioShack that would do nicely for enclosing the DIY adapter and a graphics card.
Wheres the op's power supply? Im sure thats WONDERFUL looking. Oh wait, he hid it behind his desk because it probably looks like shit.
I still don't understand why you'd post such an adapter/splitter when, as has been mentioned, the ViDock 4 Plus already has two 6-pin aux power connectors.
You don't need a splitter at all, and you're adamant that you aren't going to use the extra 2 pins...so wtf use would it be?
Not "A computer with an HD5850," just "an HD5850." If they did mean the entire system, then it's incredibly poorly worded.
You might even be able to get better performance out of the DIY solution. In some configurations, it can be attached to an ExpressCard slot and an internal MiniPCIe slot to create a PCIe 2x slot. The ViDock is restricted to ExpressCard only, and so is stuck at PCIe 1x.
According to this Xbit review, the HD 5870 uses 233W at full load by itself:
http://www.xbitlabs.com/articles/video/display/gpu-power-consumption-2010_3.html#sect0
I think their methodology of measure graphic card output is fairly accurate.
Which, like I said, is where the project box comes in. Mount the adapter, video card, and (if the video card you're using is large enough to need one) power supply inside.
He reclaimed an old ATX PSU, which saved him more money but will also require a larger project box for mounting the assembly. That's why I also recommended and linked to a bay-PSU which is much smaller.
Which runs me back into the circle of my first point. ViDock did it first and the cost difference between the two is so minimal that it wouldn't be worth the trouble.
Your replies on this matter tell me you either have no idea how these adaptor work or are desperately trying to cling to the notion that it wont work. Whatever the case is, you're wrong, about every single piece of info you tried to argue with me about.
Even if that is Furmark, it does show that the 5870 is capable of taking the ViDock beyond the rated specs of its small power supply. I wouldn't trust it for long periods of time.According to this Xbit review, the HD 5870 uses 233W at full load by itself:
Where did I say it wouldn't fit? I never gave any indication that it wouldn't socket into the plugs, only that using such an adapter/splitter would either be pointless, or would allow you to plug in a card that is very likely capable of blowing up the ViDock.When you say "that won't work" and then continue to imply that it won't fit because it's 8 pin, then you clearly don't know how it works.
Except the dock will work with a 5850, since the dock has two 6-pin connectors already. no adapter needed.I posted it as a reply to someone that claimed the dock wouldn't work with a 5850
Yes, but you linked a splitter for a reason (because you didn't check the specs on the ViDock 4 Plus closely enough). If your original intention was to use it as a simple 6-pin to 8-pin adapter I would hope your first thought would be to get the proper adapter for the job and not a splitter.you would still need the adaptor if you had a card that required an 8 pin, an example that you yourself brought up. You could do it with just an adaptor and not a splitter, but that doens't change the fact that it would work
It'll fit the plug, but there's still no reason to use a Y-splitter for anything related to the ViDock 4 Plus.You're absolutely right about one thing, I did gloss over the fact that the dock has 2 connectors. But guess what that changes about the debate you and I have? absolutely nothing. It would still work, it would fit, and power consumption is not a factor.
Not really. The Y-splitter is pointless no matter how you slice it. You failed to read the ViDock specs and posted the wrong adapter. It happens. Now can we please get on with this thread?Any way you try and justify your position, the end result is that you were wrong, get over it.
Like I told you in my previous post, I never said it wouldn't physically plug in.You said it wouldn't fit and it will, end of story
You said it as an absolute, not in reference to a specific card. Besides that, the HD5870 can draw more power than the ViDock is rated for (the Xbit review shows as much). Even if we do scale it back to the 5870, you still run the risk of issues with power consumption.As far as power consumption not being a factor, we were talking about 5850 and 5870's, not 480's and you know that. Nice try though.
Just as soon as you stop trying to put words in my mouth that I never saidAbsolutely we can move on, now that the facts are clear, unless you chose to continue to bend the facts and add other factors that weren't even part of the original discussion.
As far as saying "it won't fit" you didn't, you implied that it wouldn't by saying it "won't work" and the reason you gave is becuase it's an 8 pin. I tried to explain to you how the +2 works and your responce was that "it's still an 8 pin" The adaptor may not be needed at all, but that doesn't change the fact that it will fit, something you're still refusing to admit.
Erm, already said why. It can blow up the ViDock. I'd call that "Not working."If you weren't wrong, then explain why "it won't work?" Don't tell me it's not needed or necessary, I want to know why it flat out why it will not work. Thanks.
I read it exactly as [H] wrote it. It's unfortunate that they misrepresented the information on the conclusion page by saying that it was the cards themselves drawing that much power.What about the system vs gpu power consumption? Were you not wrong about that as well? (just incase you forgot, we were refferring to 5850's and 5870's)
lol, blow up the vdock? The adaptor uses 0 power by itself guy and we were talking about 58xx cards which we already know will work.
Use the cards as they were intended and power consumption is a non issue and never will be.
[snip]
The only thing xbit review confirms is that you can overload the power supply if you use the cards in ways they were not intended.
I read the [H] review and I did not find it to be a misrepresentation at all. I did not find where they said "the cards by themselves" can you? Or is it more likely that you're the one misrepresenting to try and back yourself up? Unless you can show where they said that, I'll go with the latter.
No, my original assessment is perfectly correct. Using a 5870 with a ViDock (with that adapter of yours or otherwise) won't work.Again, nice try but "it won't work" is still an incorrect statement, even a dozen posts later. The only thing you've been correct about is that it isn't necessary, that much is true. But not necessary and not going to work aren't the same thing.
Well, I did ask weather or not using two of these with an AMD laptop would allow crossfire (that that got lost in all this noise). I'd still like to know how that works.Unless you've got something NEW to add, I'm done here
I'm not confused. They quite clearly say "X card draws this much" when they supposedly mean "X card, and the system it's installed, in draws this much"If you read the actual article, the part that confused you would have been put into perspective. I don't think you can blame the editors for assuming, oh I don't know... That you'd actually READ the article?
More like "20,000 leagues under the sea" suddenly becoming "1,000 leagues under the sea" and acting like 20,000 never happened. Or an owners manual saying a monitors maximum refresh rate is 60Hz in the manual but 120Hz on the back-page summary.That's like trying to write a 5 page book report based on the 1-2 paragraph summary on the back of the book when you were in grade school and then blaming the book for your failure to comprehend.
I'm sure there are other things besides OCCT and Furmark that will get power usage up that high. That is beside the point, however. The hardware should be able to handle a worst case scenario, a ViDock will not. I wouldn't gamble $600 (or more) worth of hardware on a timebomb like that.So it will work until you run a completely meaningless stress test. I can agree with that.
I figured as much, though I imagine it would result in some seriously weird performance curves. Would still be interesting to see how it reacts, especially with 2GB graphics cards.Oh, and as far as crossfire. If it's even possible, I would think the lack of bandwidth would severely limit the benefits of multiple GPU's.
this is badass
hi i have lenovo thinkpad t400 with:
PE4H 2.0a with EC2C Expresscard adapter 16x
MSI Cyclone 460gtx graphics card
Corsair CMPSU-400CX 400-Watt CX Series 80 Plus Certified Power Supply
HDMI mini (C) to HDMI (A) regular 10 ft cable
ok, so the problem is, i try to put the ec2c into the expresscard slot on my t400 and it doesnt fit.
slot is bottom right corner of laptop and i dont know how to put the card in?
please help! trying to play FFXIV!!!!!
any suggestions on what i need to complete this set up or how to insert ec2c into my lenovo thinkpad t400 would help! thank you
