So i got a lg 29EA93-P, but max 1920x1080??
Discussion in 'Displays' started by Robin B, Jul 26, 2014.
  1. Robin B
    Robin B Limp Gawd
    209
    Jul 14, 2004
    So what options do i have to get 2560x1080 from my 7970? Weird that the Lg comes only with 1 Dvi and 1 Hdmi cabel.
  2. LigTasm
    LigTasm [H]ardness Supreme
    4,902
    Jul 29, 2011
    I seem to remember when I had one of those I had to set up a custom resolution for it.
  3. Robin B
    Robin B Limp Gawd
    209
    Jul 14, 2004
    Have tried but it does not show up, please is there anyone out there that can help me?
  4. Morkai
    Morkai Limp Gawd
    329
    May 10, 2011
    Not sure if it's of any help, but did you try both dvi ports on the gpu (and made sure you aren't using a single-link cable)?
    I think some amd GPU:s have one dual-link dvi port and one single, or so.
  5. Robin B
    Robin B Limp Gawd
    209
    Jul 14, 2004
    Yes i have tired everything i can think of, every dvi port and even displayport. But win 7 wont show more than 1920x1080.
    I just feel so lost...even changed the reg settings up to 2560x1080, but didnt do it.
  6. Robin B
    Robin B Limp Gawd
    209
    Jul 14, 2004
    One thing tho, it only shows as Pnp display in system.
