Just built a new Intel H370 based work pc and popped in an Intel 9560 m.2 wifi card. Foolishly I didn't realize I would need antennas to make it work Can anyone recommend compatible antennas for this card? Also is there a pci slot bracket with the antennas built in so i can easily have them sticking out of the beck of my case?
Yeah, it will work much better with an antenna. Your m.2 card should have had an antenna with it. Maybe the IT guy is testing it. https://www.newegg.com/Product/Prod...SRSZ64GHtThH7dArtUcaAv5WEALw_wcB&gclsrc=aw.ds
The OP should get some kind of antenna that he can position away from the case. The metal in the case will weaken the Wi-Fi signal.
sure like any antenna, the higher it is away from all the interference crap ie computer - the better. That's sort of a given. Please.. go shop for more Antennas.. I did my part.
