http://phishcave.com/upl/sTr4KaDVvb.png
Have no idea what to do, and can someone tell me how to configure it? Like, best options?
honestly, if you're using the NTFS filesystem you shouldn't have to worry about defragging at all. The NTFS filesystem optimizes your space just fine on its own
Don't let the image fool you. Just because they appear jumbled, it is more or less optimized and program groups are likely kept together.
honestly, if you're using the NTFS filesystem you shouldn't have to worry about defragging at all. The NTFS filesystem optimizes your space just fine on its own. But if you insist on wasting time with defragmentizers, then I'd use Recency which places your most oft-used programs in the first sector of your drive. But you will see almost no performance gain.
