DragonMasterAlex
- Jun 24, 2005
Are you using the red and white RCA stereo output on the PS3 (analogue) Prologic max
vs.
HDMI on PS3 with DD and DTS options (digital) true 5.1 with full range sound?]
If so that explains it 100%.
Buy a cheap toslink optical cable for your xbox 360 and you'll notice they sound identical. Digital is Digital - the Recevier or output device makes little difference for a digital DD or DTS signal output.
Nope, I'm using optical on both, actually, and the PS3 is connected to my TV via HDMI while the 360 is hooked up via Component. For some reason, DVD's sound better coming from the PS3 (DTS 5.1) than from the 360. Picture quality is nicer on movies too.
So far, games sound and look about the same on both. I'd downloaded the demo of Killzone 2 earlier, hoping to be blown away, but it turns out it looks about the same as any other well polished shooter on PS3 or 360
