kcmastrpc
- May 26, 2011
i'm on a tight budget.. i'd love to order a 800w corsair and be done with it but i just need some reassurance.
here's the scoop... had an older enermax 625w on my main rig (see sig) - seemed to work fine. one night while i wasn't even gaming (i have a computer repair side business and i had my bench loaded) i threw a breaker. i figured that might happen so i moved my gaming pc to a circuit in the adjacent kitchen.
computer wouldn't boot. pulled a xion 700w (i know, crappy psu) and plugged in the 24 and 8pin - pretty lights and sounds. ok, here's where i messed up. i split off the single PCI-E power line to power both my 6870's. I don't know what I was thinking really, but yea, 1 hour into a BF3 session system powers down with an electrical motor smell in the air.
so the only spare power supply i have left is a raidmax 730w. what i decided to do is use the single PCI-E cable for one card, and i used two seperate dual molex to pci-e 6 pin converters for the other. i'm assuming this is going to feed each card from the two seperate 12v 22a rails that this psu has. (this is probably what i should of done with the xion).
ultimatly... when i fire up BF3 tonight, am I going to blow this PSU up? If so, I'm just going to disable CFX, bite the bullet, and order a corsair 800w.
edit: i'm going to add that i'm amazed none of my components are toast after this debacle. don't even want to RISK popping another PSU for some extra framerates.
