SMR drive for photography?
Discussion in 'SSDs & Data Storage' started by fishrule, Aug 17, 2015.
  1. fishrule
    fishrule Limp Gawd
    338
    Nov 1, 2009
    Hi,
    I just purchased a new camera that produces staggeringly large files (60-70 megs per file). I was tempted to buy two Seagate 8tb SMR drives for storing my photography on. Would two of these drives in a RAID 1 setting be ok, or am I putting them under stress they are not meant for? I was hoping to have two in RAID 1, and then use some kind of backup software to replicate data to another external drive. Thanks for any input.
  2. cbf123
    cbf123 n00b
    50
    Dec 12, 2013
    At this review http://www.storagereview.com/seagate_archive_hdd_review_8tb they recommend that these drives not be used for RAID due to the high write loads involved with an array rebuild and the fact that the drive write performance is all over the map when rebuilding the array. It took 57hrs to rebuild a RAID1 array compared with 20 hrs for the HGST He8 drives.
    Several Newegg reviews also mentioned highly variable write speeds.
  3. rive22
    rive22 [H]ardness Supreme
    4,610
    Mar 10, 2004
    Please don't put priceless files on those drives without any other means of backup. The tech is too new, Seagate quality is dodgy, and what cbf123 said is correct.
    For the best reliability, Buy HGST or WD Black/RE.
    I also recommend burning those to MDISC blurays.
  4. jordan12
    jordan12 [H]ardForum Junkie
    9,523
    Dec 29, 2000
    Ok, wait a minute. I don't care what brand drive you use, always back it up. Plus nothing about these drives having a seagate name makes them crappy. I have 7 and love them. And drive can fail.
  5. rhansen5_99
    rhansen5_99 [H]ard|Gawd
    2,007
    Nov 12, 2001
    The 8tb smr drives are good for retrieval basically as huge storage drives, but I would not run them in a raid setup. If you need something for size and speed then maybe 6tb nas drives would be better like wd red or similar drives.
  6. ashman
    ashman Gawd
    805
    Mar 28, 2011
