Smooth Scrolling in Windows 7 - possible to fix it??
Discussion in 'Operating Systems' started by Kokain, Nov 25, 2011.
  1. Kokain
    Kokain Limp Gawd
    249
    Jan 25, 2011
    It's a waste for me to have 120hz monitor when I can only trully enjoy it during gaming or dragging and dropping files, icons, active windows etc.
    When I scroll down using the mouse button or just dragging the slide bar, I get this very jerky motion, which is really annoying especially when you want to scroll through lines of text while trying to read them at the same time, looking for specific word.
    I googled the problem but no solution came up. Luckily for Chrome I did find an extension called "Chromium Wheel Smooth Scroller", its made by the same people who made "Yet Another Smooth Scroller" for Firefox. This extension works flawless and exactly what I wanted to achieve. Unfortunately now when I look at the rest of my desktop, scrolling through Total Commander, IRC, Foobar2000 makes it really painfully obvious how shitty the scrolling in Windows is.
    My question, does anyone know of a program or a way to enable ultra mega smooth scrolling in Windows 7?
