Smell of heat
Status
Not open for further replies.
mgty23
Hi.
Hello.
PC:
Monitor:AORUS FI27Q
Cpu: 10850K with Nzxt Kraken X73 ( 60c in game )
Gpu: Rtx 3090 Gaming Oc ( 60C in game )
Ram: 32gb 2x16 GB DDR4 GSKILL 3200MHZ XMP
Psu: Seasonic Ultra Prime Titanium 850W TX
mb: Aorus 490 Pro Gaming
SSD: Crucial 1TB Nvm SSD
Case: Cooler Master Cosmos C700P
I must ask about smell of heat coming from pc case. I run Control and when gpu hits 62C and cpu 60C i smell heat coming from case. Is this normal? Not burning smell but something like hairdryer smell. Thanks.
GotNoRice
How new is your hardware? It's normal for new hardware to give off this sort of smell when it's brand new.
You can't actually "smell" heat. It's the new electronics still off-gassing chemicals, and heat accelerates this.
travm
Fyi, hair dryer smell is dust and other things on the heating elements burning. So it is burning smell. Just not burnt toast smell
No, not normal. When system gets hot, take side off case and start touching heatsinks until you find the one that blisters your finger. The chip under that is the problem. If you find nothing, you may have a TIM problem.
Or maybe you re about to have a seizure.
https://www.google.com/url?sa=t&sou...kQFnoECAUQBQ&usg=AOvVaw2Zbv62kLuxnakfyzSpPbS3
Nobu
Alternatively, if you find one that should probably blister your finger, but isn't–and actually it's pretty cold–that may also be your problem.
travm
indeed, that would be a TIM (thermal interface material) problem.
mgty23
tim problem?Not burning smell but something like warm air smell. Thanks.Pc have 6 months.
zandor
tim problem?
Heatsink paste. Probably not it though. You'd get crashes if a chip was roasting, plus you can check the CPU & GPU temps and they're just fine at around 60C.
IIRC you've had this machine a while. Have you cleaned it lately? If not get some canned air and give it a good proper cleaning. The "hot" smell is likely to come from some other component rather than a chip, like the PSU or power handling components on the mainboard. If your CPU & GPU are at 60C that means their heasink/rad is cooler than that and they are just fine. Dust build up not only causes the smell, but also increases temps and acts like a blanket when it accumulates on a component. A lot of electronic components can take a lot more heat than chips. For example some inductors can handle over 200C (that round wire coil you see inside of a PSU). A pile of dust in a PSU could easily cause that hot smell. I'd start by just getting some canned air and cleaning your machine properly if you haven't done it lately.
Also are you sticking your face in the exhaust or is the smell noticeable when you're at your desk? A hot smell can be psychological and brought on by hot air. Given your posting history I trust you to smell a hot smell if you stick your nose right up behind your PSU or an exhaust fan near to that 3090.
mgty23
its like a hot smartphone/laptop. Smell noticeable when i am at desk near pc case.
travm
VRMs dont always cause crashes, they sometimes just work until they melt off the board.
ChosenUno
How are you smelling the smell? Do you have a case fan blowing straight to your face or something?
Would be interesting to see if you can dry your hair while you game on your 3090.
travm
Don't do that. He's Trolling.
That said, hot air still doesn't have a smell. Something is getting very hot, to the point of melting or burning. We can't help beyond what's been said
mgty23
bbb
mgty23
Also i had exactly the same heat "smell" when i had 1080 Ti in past.Other case and other components. I think i am too panic heh.
travm
you are likely correct. These things are made mostly of plastic, and can take years to fully "cure". When they get hot it can cause the new components to offgas, and that has a not quite melted plastic smell. Could very well be what you're smelling, and be a non issue.
It wouldnt hurt to investigate the actual parts a little bit as suggested, just to be safe.
philb2
Or if everything runs OK, then just keep using your system and be happy.
SPARTAN VI
You know what has bad experiences and isn't upgradeable? Consoles.
You know who creates a new thread over anything that can be remotely misconstrued as a technical issue with his PC? OP.
It's okay, you're new here so you don't know about OP's history, hence why I keep recommending he move to consoles.
Slade
lol @ smell of heat. Also my 3090 hits 477W in control if left at 100%. I can touch 495W if I crank it up to 119%. Also it is NOT worth the extra 1-2 fps it gives to push it like this. I can keep it above 120fps in DLSS-1 1440p running it 85% and use 425-440W. It's great for keeping a plate warm near the exhaust at the top of my PC.
DPI
If not for the 2017 join date, all the nonsensical posting would just seem like a very determined spammer trying to boost post count until F/S forum unlocks.
Talk about barking up the wrong tree.
ZodaEX
I don't think heat has a smell. Heat is like felt by nerves, not the smell glands.
mgty23
its fine,when i am not concentrated to smell i dont smell anything.But thx i panic.
Status
