Ok.. so my NAS is running raid 0 for now, it's a new NAS and I was just setting it up.
I was checking the drives storage and one of them is listed as being Bad via S.M.A.R.T. .
But when I actually pull the SMART info everything is listed as Healthy except for something called airflow-temperature-celsius
I couldn't fit it all in the picture because the box wouldn't expand, but all of the attributes are listed as healthy except for that one.
I have two identical drives in the nas, both seagate 7200.12 and when I check the temperatures, there's a 2C difference between them.
The one listed as Bad is 2c higher than the other drive, which I don't think is horrible. Like right now one is 30C the other is 32C
I did some searching and couldn't find a definitive answer on what it means. Supposedly it means one thing for WD drives and something else for Seagate and some say not to worry about it and others so to worry about it.
I figured I'd post here and get some other opinions. Should I replace the drive or is it ok?
