Smallest case that will fit full size video card
jadams
Thanks, the Fractal case is slightly larger, and the SG10 is considerably larger.
Looking for something smaller, if it even exists that is.
WorldExclusive
If those aren't options then I would have to say no.
A case tat needs to fit a card between 10.5-11" will be larger than what your buddy has.
Volkswagen
Moderator
Staff member
Coolermaster Elite 120 or 130 should do the trick and not much larger then what he has now. Can fit an AIO watercooling unit in there as well without too many problems and they are cheap.
