So I've been out of watercooling for a LONG time but I used to be an aquacomputer fan. And IIRC, I used tubing that was smaller than the two prevailing US sizes, which I remember as 3/8 and 1/2. Also, as I remember it, back then people were starting to appreciate the more restrictive blocks.
<Actually just went and read Cather's tubing post and it was like a blast from the past>
So... I'm NOT trying to start a debate. I'm wanting to get back into WC and it looks like everyone and everything is pretty much 1/2 and the only real question people are asking is soft or hard. I'm sure I'd rather go soft (on tubing at least) while I get my feet wet (pun intended o/c) again. Also, it looks like I'm not going less than 3/8 ID 1/2 OD (10/13mm) unless I want to be sourcing from weird places. Is that true? Is there a common size smaller than 3/8 ID by 1/2 OD?
I've pretty much settled on EK block's, these:
EK-FC980 GTX Ti WF3 - Nickel – EK Webshop
EK-FB GA Z170X Monoblock - Nickel – EK Webshop
But I have no idea if those are even made to work well with smaller tubing so it may be a mute point from the start.
I'm pretty sure I'm going to use my Cooler Master HAF XB EVO case so I'm thinking a 280 rad and a 120 rad in series. I have no idea which but I was thinking maybe the Black Ice XFlow Cross Flow because I want to go out one side and back in the other.
I've got several never used pumps and rez's from back in the day but I may still buy new if things have changed enough.
Any thoughts?
EDIT: I should have said I'm not going to be doing any major overclocking and may not overclock at all. I just want my parts to stay cool without running a wind turbine and I want my system to look cool, again, pun intended...
Any thoughts?
