Small notebook that can dock with 2+ external monitors
RevMen
I'm starting a new job that involves a lot of travel, but still a lot of desk time. I'm on the hunt for a small, travel-friendly notebook or ultrabook, preferably with no optical drive. At home I'd like to be able to just plug it into a dock closed and use external keyboard+mouse and multiple ~20" monitors. My dream would be to have 3 external monitors, but 2 would be good, too.
The Lenovo T420s seems like it will get me there, but that might be more machine than I need. I also don't know if I'll be able to close the lid and not use the built-in screen at all.
The X220 might work, but I can't tell how well it would handle multiple external monitors or if I could dock it closed.
The Dell docking stations seem pretty crappy.
I like the ASUS and Acer ultrabooks, but they don't seem to have any kind of useful docking stations.
Any ideas?
Outlaw85
I can't speak for any other laptop/dock combo but Dell. I am not a huge Dell fan, I wasn't given an option. But I am overall, happy with it. While it does show listed to come with Win7, I use Win XP 32bit.
I use a Dell E6400 with E/Port Plus 210W and 130W Port Replicator on a daily basis.
Supports dual monitor (when laptop is closed). I current have 2x 19" monitors.
Dock provides additional USB ports
Dock supports DVI, VGA and display port (not all at the same time)
Power button on dock controls power on/off of laptop
Not large and bulky for all the additional ports you get
Dislikes:
Only supports dual monitor
Cannot use more then 2 of the video options at once.
Undocking and redocking may rearrange your desktop icons (not a huge con but note worthy).
Dual monitor support can be limiting on 130W version due to compact size (Single DVI, VGA, display port)
Honestly, I can't say anything bad about it except maybe the limit of monitor support if requiring more then 2 external. I haven't (but want to) tried the USB video adapters to see how well this would work. For basic day to day use and from what I've read on a few of them, they may be a good solution. Also, they aren't too expensive (~$50us for a good one).
Hope that helps,
Outlaw
**update**
Was just searching and found that the e6400 comes in a 14" model. The ones I found were refurbs, but for $250-$300, it has respectable specs (Core 2 Duo, 2GB+ ram, 160GB HDD...etc)
https://www.google.com/search?q=del...or.r_gc.r_pw.r_qf.,cf.osb&fp=ce38ca0d22cdee7e
Oh and BTW, I am not a dell employee. lol
knight427
If you really want 3 monitors, you need something with a strong GPU and if you want to buy it now, it needs to be an AMD GPU. Your best beet is to buy a Dell M4600 from their business outlet. Get a model with Firepro 5950 gpu.
You can use the laptop screen plus your 2 external monitors. If you get the docking station, you can do up to 5 external monitors!
There was a 15% coupon for their outlet earlier this week. Not sure if it still valid, but certainly the selection might be picked over by now. You should be able to get a base model with M5950 for $700-$800. Note that it comes with a 3yr NBD on-site warranty.
The HP 8560w offers the same gpu, so it would do the same ting, but HP has a crappy outlet. Lenovo W520 only offers Nvidia gpus. As such, the Dell price is unbeatable.
You can also do this with an AMD gaming card, but obviously you can't get a docking station for a gaming laptop (at least not the type offered by Dell/HP/Lenovo on their business class machines).
If you wait for Ivy bridge, I think the Nvidia gpus will support 3 monitors (they only do 2 for now as far as I remeber).
kevinsbane
Any ideas?
You can dock Thinkpads closed, but you do need to set the setting so that your machine doesn't a sleep when the lid's closed. The X220 cannot drive 3 monitors at once, only two. It handles my CAD work decently.
Portability, the thing is just awesome. I love how small and light it is.
