Slow speeds
Discussion in 'Networking & Security' started by reaper7534!, Jun 10, 2018.
  1. reaper7534!
    reaper7534! n00bie
    58
    Feb 13, 2016
    My gaming pc is cruising right along with and downloading at speeds which are consistent with my connections, 100 down.
    Now when I download with my other PC, it is downloading very slow ...early DSL slow.
    Both are on a gigabit network fed from my main router, a ASUS 68u to a switch in my room which has bother PC's plugged into it, also gigabit.
    Adapters in both PC's say 1 Gbps and both PC's say the same thing when I run speedtest.net
    It's only when I download, one is drastically worse than the other. This is probably why my OBS streaming quality is shot.
    I swapped cables from one to the other and still the same thing as well as several different ports on the switch.
    6700k - running great
    3570k - not so much
    any ideas where I should check, or is the motherboard adapter foobar ?
  2. Ultima99
    Ultima99 [H]ardness Supreme
    4,743
    Jul 31, 2004
    Doesn't sound like you've tested internal (LAN) transfer speeds at all.
  3. pendragon1
    pendragon1 [H]ardForum Junkie
    10,696
    Oct 7, 2000
    yeah test internal speeds and also try another browser on the problem system.
  4. reaper7534!
    reaper7534! n00bie
    58
    Feb 13, 2016
    Here you go guys....
    [ 4] local 192.168.29.251 port 50094 connected to 192.168.29.122 port 5201
    [ ID] Interval Transfer Bandwidth
    [ 4] 0.00-1.00 sec 107 MBytes 896 Mbits/sec
    [ 4] 1.00-2.00 sec 106 MBytes 892 Mbits/sec
    [ 4] 2.00-3.00 sec 106 MBytes 893 Mbits/sec
    [ 4] 3.00-4.00 sec 106 MBytes 893 Mbits/sec
    [ 4] 4.00-5.00 sec 106 MBytes 889 Mbits/sec
    [ 4] 5.00-6.00 sec 106 MBytes 893 Mbits/sec
    [ 4] 6.00-7.00 sec 106 MBytes 887 Mbits/sec
    [ 4] 7.00-8.00 sec 107 MBytes 899 Mbits/sec
    [ 4] 8.00-9.00 sec 106 MBytes 890 Mbits/sec
    [ 4] 9.00-10.00 sec 107 MBytes 894 Mbits/sec
    [ 4] 0.00-10.00 sec 1.04 GBytes 893 Mbits/sec sender
    [ 4] 0.00-10.00 sec 1.04 GBytes 892 Mbits/sec
  5. pendragon1
    10,696
    Oct 7, 2000
    cards fine, software somewhere is causing it. try another browser, turn off firewalls, look at whats running in the background etc etc. maybe make a new account to see how it acts.
  6. reaper7534!
    reaper7534! n00bie
    58
    Feb 13, 2016
    Had been using Chrome..... tried IE and disabled firewalls... same thing. .... I'll try another account
  7. reaper7534!
    reaper7534! n00bie
    58
    Feb 13, 2016
    Any other ideas, I may try to toss in a WiFi adapter just to see what it does
  8. SvenBent
    SvenBent 2[H]4U
    2,196
    Sep 13, 2008
    check if you are using jumob frames on any of the devies.
    if so disable it
    Jumbo frames reduced me transfer speed by 50% for some weird reason. Worth to test
  9. reaper7534!
    reaper7534! n00bie
    58
    Feb 13, 2016
    Not enabled on Windows of either machine, but was enabled in router, still no change after disabling
  10. Brian_B
    Brian_B [H]ard|Gawd
    1,465
    Mar 23, 2012
    Both static IPs with same DNS?
  11. pendragon1
    10,696
    Oct 7, 2000
    static shouldn't matter as the issue is with downloads not internal networking.
    check your hosts file and proxy settings and clear your dns cache.
  12. reaper7534!
    reaper7534! n00bie
    58
    Feb 13, 2016
    Progress....did a windows "refresh" which basically uninstalls all apps and certain drivers. One of the drivers that was uninstalled was Realtek PCIe Ethernet Controller. I downloaded originally from Gigabyte site, this is a older board, Z77. I assume Windows installed their own stock driver. Now to install programs one by one and check speeds. I will not install any drivers.
    I downloaded 100 mb file in about 10 seconds or less
    pendragon1 likes this.
