Hi,
I have a Windows MCE PC and a Vista PC connected via wired CAT5 through a D-link DL524 router. If I initiate a file transfer using the Vista PC from the MCE PC to the Vista PC or from the Vista PC to the MCE PC the transfer will only go to about 3MB/s. However, if I transfer the same file using the MCE PC I get much faster rates, maximum about 80 MB/s.
It doesn't matter which directio the transfer goes; if it is initiated by the Vista PC it is slow, if it is initiated by the MCE PC it goes fast.
What could be causing this slowness on my Vista PC? Is there anything I can try to get it to acceptable levels?
Thanks.
Thanks.
