Slim Receiver VS Soundbar VS Theater in a Box VS Powered Monitors
Discussion in 'Home Theater PCs & Equipment' started by Outlaw85, Dec 19, 2018.
  1. Outlaw85
    Outlaw85 Gawd
    728
    Feb 7, 2012
    Yes, another one but need some help. First. I'm not an audiophile but do enjoy balanced sound. I still don't have anything great. Yeah.. I'm all over the place on equipment.
    Current setup:
    TV: Samsung PN51D450
    Receiver: Sony STR-DH740
    L/R Channel: JBL Monitor 4206
    Subwoofer: RCA SW60P (from Radio Shack 15+ years ago!)
    The JBL's have sounded the best to me so far but are a little large. Compared to DCM Cinema 1's and Bose 161's. The wife (NO) wasn't a fan of them sitting on the floor angled up with a couple of game boxes.
    Long story short. My dad got us a TV stand with elec fireplace to replace a beat up tv stand. Wife (NO) hinted at a soundbar and I said "You will get the wrong one", she replied "Thanks for the confidence". I did consider using my Creative 2.1 pc speakers (T2900) but doesn't have optical in or remote controls.
    BUDGET:
    FIRM <250 but she was already looking at bars ~150 range.
    Now that you know the high-quality equipment I'm working with... lol. Some things I'm looking for
    -A good 2.1 would be fine. I'm fine with using the SW60P if needed. It's not top notch but does add some low's the bookshelves/soundbars don't.
    -If it has a receiver/amp, must be able to fit the shelf. Think the size of cable box/DVD player
    -Would like radio but if not, BT for easy music playing.
    -Maybe some powered monitors? Klipsch R-14PM Powered Monitor?
    Slim receivers aren't cheap. And the cheap ones are lacking in/outputs
    Soundbars, Wife (NO) was looking at a VIZIO 2/3.1 something for 148. I had been looking at the Samsung/JBLs in the 150-250 range but haven't been listening to anything in person yet. These seem to be all over the place for in/outputs but usually have a min of optical and BT.
    Theater in a Box. Only reason I was really considering was if I found one with a smart wifi bluray player. Otherwise overkill to use as 2/3.1 plus the cheap ones usually only have option for passive subwoofer and limited connections.
    Thanks,
    Outlaw
