ADRENALIN_2099
- Apr 26, 2008
I recently acquired another GTX275 very cheap and i thought i would try out sli.
everything works like a charm until i last more that 5 minutes (some times 30 seconds) playing a game. The pc shuts down. Turn it back on and its fine.....until i try and game again.
i have a Antec Quattro 850 (850W) and im sure that it can provide me with enough power but i do not know why its overheating (when i take touch the PSU its very warm). Now, i added one of case fans to the rear or the unit (so it would blow air in the psu) to try and get it to not over heat, the pc takes longer to shutdown, but i still does...
you guys have any ideas?
what i thought about doing was getting this adapter http://www.frozencpu.com/products/5..._Power_Supply_Adapter_Cable.html?tl=g11c28s91 and getting another ~370Watt PSU (probably another http://www.amazon.com/Power-Cooling...2?ie=UTF8&s=electronics&qid=1264692618&sr=8-2) and using the that PSU just for the other card and fans.
I know that getting a bigger (higher wattage) PSU will solve that issue, but if i can fix it for ~$60 i really do not want to spend $200 on a new PSU.
My specs are these:
Core i7 860 @ 3.5GhzStock vcore)
Biostar T5 XE CFX-SLI
RAM - 8GB (2x4gb) G.SKILL Ripjaws
Evga & BGF Geforce GTX 275 SLI (stock)
Creative Xfi XtremeGamer
Antec TruePower Quattro 850 Watt
CoolerMaster HAF932
2 SATA green HDs
1 regular SATA HD
i have 3 Scythe Ultra kaze 3000 120mm fans, one 120mm fan (stock H50 fan), and the top and fromt stock 240mm case fans.
just about every PSU calculator tells me im under the 700W mark (expect for new eggs, that tells me i need a 873W PSU...)
My specs are these:
CoolerMaster HAF932
2 SATA green HDs
1 regular SATA HD
