Hello All.
I have posted here my 6 moths old LianLi built. But now I have decided to do some changes.
Impression of this case is just fantastic. It is small but fits full ATX motherboards and full length graphic cards.
To summarize my previouse adaptation mod - I have cut the window, blowhole on top and tried to polish interior. I did also some sleeve with techflex material. I have survived with it just half a year...
After half year I've decided to change this case a little... An I'm still in progress
New concept is based mostly on MDPC-X sleeves. I want my case to show as much cables as possible! Airflow performance has to be in the same level as before. So it will be a challenge.
I have just few steps to finish this concept:
1. Sleeve (I'm surprised - I have used 40m of sleeve material and had to order 20 more)
2. Paint interior on black. AKA mirror polishing was a not bad idea but it failed. This step will be done on September.
3. Cut additional "mini" windows in side case. I still don’t know what kind of window it will be. What I know that I need to see part of cables placed behind the door
Ok. I'm still doing my sleeves and waiting for additional package from NILS
Pin extractor
Orange UV SATA Sleeve
And more sleeves…
…next days… and moooore sleeves…
…beauty UV SATA
And the longest journey - PSU Sleeves!
Almost 40m cables in one small case :O
I had to buy SSD mount brackets. You can see sleeved cables mountain laying behind it
And it looks nice…
Now I'm waiting for more sleeve materials. There is still a lot of job to do
Cheers,
Burdoror.
Pin extractor
And more sleeves…
…beauty UV SATA
And it looks nice…
Cheers,
Burdoror.
