Siri - a sack of bricks
marshac
American Hero
I know there's a few out there that like Siri, but from most of my interactions requesting information, she falls apart - can't search the internet while driving, etc. Google assistant has (IMO) always been much better, and there are some work-arounds to get it into the iPhone "hey siri... ok google" although this doesn't work while using Carplay. BestBuy has the Anker Bolt on sale today for nearly half off ($30 vs $50)- this is a lighter adapter that provides Google Assistant and connects via bluetooth via the Assistant app. I've generally read that it doesn't work with CarPlay, but at half off, I thought I would give it a try. Once I got it set up the way the product wanted to be set up Bolt -> iPhone -> Car with Bluetooth being used for both linkages, I switched over to carplay and gave it a try. Worked fine. It can't launch other applications such as Spotify, but Siri does fine with these - for the questions such as "what are some nearby movie times" I now have Google in my car.
https://goroav.com/pages/bolt
https://www.bestbuy.com/site/anker-...oogle-assistant-black/6327774.p?skuId=6327774
UnknownSouljer
Siri is definitely behind the competition.
I'm glad that Apple has definitely taken note and behind the scenes they've added a lot of people to their AI team to actually do something with Siri, because quite frankly even text to speech is lacking in iOS.
It's probably going to take a while though, so glad you found a workaround you like in the meantime.
vegeta535
I don't use apple products so I can't comment on that but with my accent Android is totally useless for me. It never gets it right.
