Single mode vs multimode fiber
Discussion in 'Networking & Security' started by shadowwyvern, Nov 14, 2006.
  1. shadowwyvern
    shadowwyvern Gawd
    604
    Sep 22, 2005
    Can I use multi mode equipments (100FX) with single mode fiber? The runs would not be terribly long, certainly not 2km, but at least several hundred meters. I am trying to figure out if I can get a cheap setup to mess with the stuff, as I already have a fiber equipped switch; I just need the fiber and a media converter
  2. niccoli
    niccoli Limp Gawd
    432
    Feb 13, 2002
    The short answer is no, the core size of multi-mode fiber is larger than that of single-mode fiber, single-mode fiber only allows 1 wavelength of light go through it while multi-mode has a larger core so that you can use multiple wavelengths of light. Single-mode fiber has a core size of around 10 microns in diameter, multi-mode has a core size of around 60 to 80 microns.
  3. valve1138
    valve1138 [H]ardForum Junkie
    10,037
    Apr 14, 2003
  4. shadowwyvern
    shadowwyvern Gawd
    604
    Sep 22, 2005
    Didn't think so... thanks.
