Eyeball Kid
- Jan 31, 2002
Is anybody playing at this res with a single 770? Is the 770 powerful enough to push this? My current card is a 2gb model, btw.
Everyone here seems to operate under "maxed out or nothing". Which, of course, is stupid. You don't have to do this.
You can make a single 770 work. Everyone here seems to operate under "maxed out or nothing". Which, of course, is stupid. You don't have to do this. If you don't mind lowering settings, you will be fine. In fact, I've tried this in many games and I can more or less assure you that AAA titles do not look any different at very high vs high settings. Random examples: You can make metro 2033 run absolutely great with AAA, DX11, and ADOF + physx turned off. But if you turn all of those on (ADOF of physx) it will literally chop your framerate in half. BUT THE GAME DOESNT look different. Same for crysis 3. To my 20/20 vision, at 1600p,high looks 100% identical to very high. You can also lower shadows and water another bit for a higher framerate. Try it for yourself. These games do not look different with a few dials turned down. You can also use FXAA instead of MSAA which is also a huge framerate boost.
Regardless of what anyone states here, you CAN make it work. Just use common sense. Common sense means you won't max everything out with ridiculous levels of 8X MSAA or anything along those lines. Use high instead of ultra, and the games WILL NOT look different. This I assure you. Crysis 3 looks exactly the same at very high and high, but the framerate difference is immense.
And there's also the fact that not all games are super demanding AAA titles, for all of those, they will run great.
It all boils down to whether you're willing to spend another 330$+ for ultra settings. It's up to you - i'd say give it a try with a single card, and if you aren't ridiculous about maxing stuff out, you will enjoy it just fine. Use common sense about game settings. I personally think the maxed out or nothing mindset is pretty dumb, but whatever. It's all subjective. And if you try a single card, feel like it isn't doing it for you, buy another card later. My suggestion is to try a single card first and see how you like it. I've tried it at various times and found that it was perfectly workable. PERFECTLY do-able without much compromise at 1440/1600p.
<slow clap>. Good post.
Yeah, that was kind of my thinking. I usually back off ultra settings, and run with vsync disabled anyway. I'll (generously!) let my wife buy me a new card for Christmas, and get the monitor now, I think.
Then you certainly are not playing some of the really demanding games and/or have your own definition of maxed out.I have a 670 and 1440p. I max out every game I play.
I don't play BF4 though, so no advice there. I'm also not bothered by sub 60 fps, as long as it doesn't stutter (generally starts happening sub 30).
My thoughts exactly
I downgraded about 4 months ago from a 7970 to a 660ti becasue I wasn't gaming a lot. I still can run a lot of games just fine.
It comes down to as he said above what you are comfortable running. If you want to run the newest games on ultra at 1440p, you might as well buy a 780/290. But if you are able to make concessions you will be just fine.
btw, once you get a 1440p monitor you will be ruined. You will never be able to use a low res/non-ips monitor again. You have been warned.
what's the point of 1440 with low IQ settings?
I HATE jaggies. I'd rather step back a bit on IQ than notice them. For as many pro-1440 articles, you'll find the same amount of anti-1440. I've got an older 1080 monitor: what I'll lose in IQ, I'll gain in contrast, viewing angles, response etc. My 770 may not push this to the max, but the card I'll buy a few months down the line will split the expense up a bit. Sure, I could splurge on a 780 or a SLI set-up now (Last time I had a multi-card setup was a Matrox Mystique + 2x Voodoo 2 8MB SLI PCI setup), but I've got the income to wait a while for the next gen, and enjoy the older games I've got queued up to play right now, at decent FPS. FWIW, this system I have now has been updated incrementally over the the last 21 years from a DOS based 486-DX2 66Mhz Vl-Bus system in 1993, where I used to have to run Mo'Slo to slow games down to a playable speed: my first monitor was a generic 0.39DPI 640x480 CRT, so I'm at ease with compromise AND GET OFF MY LAWN!
aliasing is noticeable at 1440p, even 1600p. also, you came here (HARD forum, i remind you) seeking opinions, but instead, only accept validation on your soft purchasing decision?
Thank you for your interest in the position of thread Troll. Unfortunately, we are not hiring at this time, but best of luck in your future endeavors.
You can always use FXAA which has, basically, no performance hit at any resolution. Also, the hard vs soft stuff is long in the tooth. Let's not be silly and condense every budgetary issue into that, christ. Not everyone here spends 1000s on GPUs. I mean it's fine if you want to do that, i've done it MANY times myself. But when you have real budgetary concerns, sometimes budgetary concessions have to be made. Sometimes when you have a massive mortgage and multiple car payments, you're not always going to want to spend 600$ on another GPU. And sometimes even when you can, the woman will raise too many issues with it. And let's face it. Having an angry wife around the house. NOT fun stuff.
That's just how it is for many folks in the real world. And when that is the case, you can easily make a single GPU work at 1440p or 1600p - I have done it. Simply lowering 2-3 settings in most games while using FXAA will result in the games NOT looking different at all (I have examples of this in a prior post) while running significantly better.
If you want to max everything out across the board, i'm not knocking that decision. It's all in the eye of the beholder. Either decision is a valid one, and you CAN MAKE a single GPU in fact work fine at 1600p. Period. The minimal concessions you do make don't affect image quality to any significant extent, but if you want to spend more money for ultra settings, you're free to do so. I will say that I believe the "maxed out or nothing" mindset is kinda silly. Think about it. Even a GTX 780ti or 290X cannot max Metro: LL or crysis 3 out at 1080p ultra and maintain 60 fps 100% of the time. When the best of the best can't max games out and maintain the best framerate, something is wrong. Sure you can spend 600 more bucks for SLI or Xfire with another GPU. Then you can run ultra to your hearts extent. But is that the best decision for 100% of buyers? Nah. Sometimes lowering those 2-3 settings is preferable.
I mean, i've played so many games where I turned settings down and the resulting image quality was absolutely no different @ 1600p. Yes, if you go to the lowest settings there is a difference. But you can generally gain 30-40 fps by simply lowering some of the overkill settings, using high instead of ultra, using FXAA instead of MSAA, and get a huge framerate boost without any real image quality difference. Like I said, I've experimented with this and couldn't really find IQ differences when I tried.
not trolling. grow up and face the facts. a 770 @ 1440 is a compromised experience unless you're playing older games. are you asking for opinions or seeking validation?...
Anybody know when the next-gen is coming? Seems like there's always gonna be some compromise at 1440, but reading through the replies I think I can make the single 770 work for a while. Next-gen I'll go with the top-end model to avoid this again in the future. Plus, I've got a 4 week old baby, all my money seems to be going on diapers...
It's been a good run: I've been posting to this forum for over 12 years, and yours is the first needlessly obnoxious reply I've ever gotten. The guys here are awesome, taking time out to offer up opinions and advice, so you're an aberration. I normally don't respond to people like you online, but I will (this once) address your comment, just because you're acting like such a little girl: if you read back through the thread, you'll notice that I ask for advice, receive varying opinions, then make a decision, which I then lay out my reasoning behind. I didn't crap on anybody that laid out an opinion that I ultimately didn't hold to be the same as mine - I simply made a different choice. I'm baffled as to why you're fixated on me "Justifying" (Read: "Explaining") my decision, but probably you're just lonely. Anyway, please take your little confused/rolleyes emoticons and your high blood-pressure, and go someplace else, 'cos you're not welcome here.
