simplest way to take a screenshot from an avi?
b1m2x3
well, i want to make a photo sequence from this AVI i have of me... but i cant just take a screenshot with windows media player.
anyone know of a simple way to take screenshots from avi's?
You have to use a program that can access the overlay memory buffer.
Snagit or the like.
Other than that, if you have a second machine you can remote into the first one from, pause the avi where you want to capture it, remote in, then capture a screenshot of the remote control app inlcuding the avi picture.
Screenshots in WMP:
Tools--> Options--> Performance--> Advanced
Uncheck both instances of "Use Overlays"
Done.
thanks guys!
:cool:
yayyy
I believe an alternate way would be to disable any video hardware acceleration from device manager...
I use Mr.Captor 3.01. Very nice software. check it out for more info.
VirtualDub will let you get a specific frame fairly easily.
edit:
enjoy
