Hi guys.. Couple questions,
-1- Will I have any trouble installing the Swiftech MCR220-QP dual 120mm radiator into the top case fan openings on the TJ09 without any modification?
Seems like an ideal place I am just not sure on the fitment.. Figured someone might have some experience w/ this case and attempting to put the rad at the top of it.. I havent purchased the case yet but do have the rad..
-2- Would this case be good choice for WC setups w/ all WC parts inside the case? is it to big? Any other case suggestions for WC?
My machine has Samsung SATA DVDRW, 1 500GB 7200.10, 8800gts 640, corsair 620hx, DS3R, E6750, 2GB Ballistix 800.. WC CPU only at this point.. So.. The machine will be rather uncluttered..
Thanks!!
Thanks!!
