HardOCP News
[H] News
- Dec 31, 1969
For those of you that want an AIO cooler, but are tight on space, should give this Silverstone TD03-SLIM CPU cooler review at Modders Inc. the once over. For comparison purposes, you can see our evaluation here.
Since memory manufacturers have all but given up making sensibly sized RAM heatspreaders the standard, AIO’s have become the cooler of choice for many. While it provides plenty of clearance around the pump/block unit however, not all cases readily accept radiators. For small form-factor and slimline cases, it is even more difficult because they are not often designed with AIO’s in mind. Silverstone however, has an AIO solution that fits their own line of low-profile SFF cases as well as those cases with only a single 120mm fan mount available.
