JoepieDeSnoepie!
- Jan 14, 2014
As a friend has that chieftec one it's easy for me to answer: the fan + cables is different, insides are the same.
While advances in engineering and components have made modern high-end SFX PSUs quieter than ever, there is still inherent limitation with 80mm fans ability to dissipate heat at maximum loading conditions while maintaining satisfactory noise profile for users sensitive to higher-pitch sounds. With this in mind, SilverStone has released a lengthened variation of the SFX form factor called, SFX-L. With 30mm of added depth, a SFX-L power supply has enough room to fit a 120mm fan, thus its maximum load noise can be not only lower in intensity (via slower fan speed), but also lower in pitch (due to larger fan size).
"Loud or high-pitched sounds, even if they are at a distance or virtually inaudible to others, may be extremely distressing for someone with autism."I wonder who they could possibly be referring to
I wonder who they could possibly be referring towhile maintaining satisfactory noise profile for users sensitive to higher-pitch sounds
We don't have autism right? Right?
If that's the excuse I have to use to get quiet PC components manufactured, I've got autism"Loud or high-pitched sounds, even if they are at a distance or virtually inaudible to others, may be extremely distressing for someone with autism."
Is there any reason why a 92mm slim fan like the lovely Noctua couldn't be used in a 100mm deep PSU?At 100mm deep, however, the standard SFX PSU is also limited in fan size to 80mm
While this supply is designed in EU, it is mfg. in China. Released in October 2014 (EU).
http://www.chieftec.eu/en/psus/smart-series/sfx-500gd-c.html
Yes that's the one by ID Cooling.
As to who manufactures these Coolermaster/Akasa/ID Cooling 120x120x15mm fans, my guess is Everflow.
They should've just said "For users that can hear the chirp of a songbird and the click-clack of a train on the tracks, we've proudly ditched our plans for using yet another shit 90-cent fan, and have instead had the sense to use one of retail quality."
We shouldn't be expecting this PSU to be dead-silent while the fan is running, most ATX PSU's can't even do that with 25mm thick fans. The 920rpm minimal cycle is most likely a balance between the fan's starting range, minimal airflow and low noise. If this is not a PWM fan anymore but a voltage-based fan, it's characteristics change too.This seems very promising, though personally I'd prefer a lower initial rpm. Should still be silent enough though. Should.
The GeminII M4 fan is fairly inoffensive. Its acoustics are typical for a decent sleeve bearing fan. It has a buzzy and turbulent sound at higher speeds and is generally smooth at lower speeds. Being a 1,600 RPM model, it has quite a large noise range. The cooler is an almost inaudible 12 dBA@1m at 5V, while at 12V, it measures 30 dBA@1m.
Ah, thanks! Never taken the case off a PSU to look inside.Yes because there is a power socket and active filter PCB in the way.
Damn. I wasn't expecting a slim 80mm fan to be stronger than a slim 92mm fanAlso the Noctua 92x14 is not strong enough to cool either the ST45SF-G nor the SX600-G
My reasoning is based on assumptions, so please take it with a grain of salt. inb4 tl;drAny reason for this guess? I can't find anything like this made by Everflow.
andThe next fan we will talk about was provided by the well-known SilverStone Company using a lot of Everflow solutions for their products. The fan is called Suscool 121 and is shipped in clear plastic casing
This fan uses what is known as “Enter Bearing” and in reality is a common sleeve bearing with somehow extended lifespan.
Fluid bearing fans have the advantages of near-silent operation and high life expectancy (comparable to ball bearing fans). However, these fans tend to be the most expensive. The enter bearing fan is a variation of the fluid bearing fan, developed by Everflow.
<cropped>
You know what would be even better ? If Tony Ou cleared it up
Has anyone heard what happens when the fan kicks in at 41 degrees and the temp falls below 41 degrees? At what point does the fan turn off? Is it at a certain temp, or after a certain amount of time?
I'm just really worried about hovering at that 41 degree mark and having the fan turn on and off and on and off non stop.
Indeed.The designs and names of bearings seems a murky and uncertain world.
I don't know Everflow actually make a product catalog available (I can't access their site), but I think it's common for OEM manufacturers to never publicize information on their products that are catered for particular requests by other companies. Also, Blade shapes do help in finding which fans are identical to each other but I think similar "ideas" have often been adopted/mimicked by different companies. Like notches and ridges on fan blades, some company started adding them to reduce noise and many others followed suit. So I would also look at the blade count, strut design, hub size, hub shape (flat vs round on the intake side), etc. to make judgements.However, in the same way you point to the bearing, I point to the shape of the fan blades. Evercool do not sell any fans where the blades are shaped like the Akasa S-Flow. As well as the Viper and Apache models, Cooler Master also sells a variation called XtraFlo, just like the name of the slim fan.
That's very unlikely since these fans came out at totally different times. Coolermaster's XtraFlo Slim 120 was already available as part of their CPU cooler Gemnii M4 in January 2012 in my country, whereas Akasa AK-FN078 came out January of this year in my country. As for the ID-Cooling slim fan, I don't remember exactly the first time I found it, but I think I found it much later.Isn't it just simpler to assume the three Akasa / CM / IDC are making this fan as a collaboration?
Is it a generic name? I don't think so. What about licensed? Yes it's possible, I can't deny that. I'm inclined to believe the likeliness of a fan advertised as Enter Bearing being an Everflow fan is high, from my experiences with seeing/owning many OEM fans none of which have (EBR) printed on them except for the ones by Everflow, but that could be because many of them were ball bearing fans.And that the "enter" bearing is either licensed or a generic term?
The controller could be different, the OEM is Sirfa instead of Enhance and Sirfa has experience making semi-fanless PSUs with their Astro line.
Maybe its already been mentioned in this thread but I got a reply from a Silverstone representative that German stores would have it up for sale sometime in january.
Thanks! I've update the OP.
