- May 18, 1997
SilverStone Strider Platinum ST1000-PT PSU Review - In today's world of PC hardware, it is not exactly easy to build a system worthy of needing 1000 watts of power, but if you happen to be doing that, the SilverStone Strider Platinum series has a solid unit that likely fits your budget while ticking off all the high end check boxes, especially efficiency.
