If only use the single PCI-E 6 pin cable for graphics card, what's the best graphics card available?
GTX 670 (mini only)
GTX670-mini uses an 8-pin PCIe which can pull twice the amount of power of a 6-pin PCIe (150W v 75W).
GTX 670 (mini only)
Jonnyguru has a review up if anyone is interested: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=368
I have an i5 3350, 660ti and the fan does not even start when i play GRID2. I use an 2xmolex to 6pin pci-e adapter. You will probably be fine depending on the rest of your build. Mine has one SSD, 3 fans, and the pump from the AIO WC.
Ps: I also have one fan facing the back of the psu, idk if it helps or not...
Unfortunately my unit started making clicking sounds in idle mode. Is this a well-known issue, can anybody confirm?
Will RMA my unit with shop and see what happens.
Maybe there is some heavy voltage ripple on the fan power.
Shouldn't the ST30SF fan be completely off at idle?
Maybe PSU temps are at a certain threshold where the fan just keeps kicking on and off?
