1_legged_sheep
- Apr 20, 2010
Decided to put an H50 in my Silverstone SG05. I wanted it to be able to still fit the DVD burner and hard drive in the normal caddy.
Case Naked:
The H50 backplate fit fine on my ECS H55H-I (Take note Gigabyte!!) without smashing anything on the back of the motherboard.
I used a Scythe Slim 120mm fan (the 2k rpm one) so that the video card could fit easily. You can barely see it in the pic is soo thin:
I did have to mod the DVD/HD caddy a bit. There was some extra metal that isn't really needed to support the 2.5" hard drive I had to remove to clear the radiator:
Fully assembled (I will clean up the cables later today):
The results, 4.4ghz with the vcore set to 1.41v, mem at 1.65v, VTT at 1.25v, spread spectrum off and turbo boost disabled.
Case Naked:
