It's not quite possible to fit decent heatsinks in such a small enclosure as the SFX form factor.
Maybe I got lucky, or maybe I'm just not sensitive to it, but I never noticed the stock fan on my ST45SF-G sounding bad. Still on the loud side under load, but at idle it wasn't a problem.My new v2.0 ST45SF-G, while not exactly loud, has the worst sounding fan I've ever heard.. ever. At idle all I can hear is its stupid crunchy sounding fan (and that's audible above 4 other fans). I'd throw that POS in the trash if I had any other option besides tearing it apart and trying to fix it myself. Really find it hard to believe that Silverstone spends this exorbitant amount of time on R&D for a $100 PSU, just to toss the nastiest junk fan they could possibly find in there
The semi-passive 300Watt unit looks almost exactly like the 450W bronze version ... no extra heat sinks.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=368
Yes but 600W is twice the 300W. Unless it's super duper efficient, it will need active cooling.
I'm in the same boat as you Necere, but I have never even heard the fan under load --> my reference R9 290X wins in that regard.
Crap, I must retract my statement. Suddenly, the fan is quite noticeable now. I don't know what happened but it is louder than before. Maybe the fan's bearings are damaged ?
Just swapped out fans and removed the grille. I'm getting the clicking sound that another user reported a while back, even with the fan installed outside of the case. I think it is just a sound property of the fan.
Just out of curiosity, I emailed Noiseblocker support that some people are experiencing this clicking sound with the BlackSilentPro PC-P 80x15. Got a response from a Herr Döhring that you should apply for RMA and have the fan replaced.
Too bad the first thing I did was cut up and resolder the power cable
Not a cheap fan.
The crunchy noise might be explainable: I just changed the original fan with the NoiseBlocker (bye-bye noise) and I noticed one of the mains wires (the white one) was touching the fan. I jammed it away with a tiny screwdriver. That might be your problem and thus an easy fix.Sorry to hear! I've noticed that my "crunchy" noise seems to come and go. It's usually constant, but occasionally it'll sound like a normal fan for a few seconds every once in a while. Not really sure how to describe the sound, but it sounds almost dirty.. like there's grit stuck inside with the bearings or something.
I took pictures as I opened mine up again, the white wire was keeping the fan from turning around.
It also seemed to be like that originally, as the black cable was still glued down properly.
It's fine
What we know about the ST45SF-G is that the 450W designation is artificial. Likely Silverstone "downgraded" the max power output in order to have it score better in the 80Plus test, ie gold instead of silver efficiency rating. Testing by Chiphell has shown the unit capable of over 40 amps sustained (=480W) on the 12V rail alone. They said when it finally failed at 48 amps (=576W), it was due to overheating and not necessarily due to electrical limitation.
The reason we usually say "yes but no overclocking" is more because at higher draw, many units seem to suffer from increased voltage ripple. Then your GPU will crash because the voltage to the components is less stable. Enough juice, so to speak, but not a steady flow.
I mean the GPU will shut itself down. The ripple is not nearly so bad that it would cause damage. It's still well within ATX specification.
Seems to be showing a different AC plug and fan layout than the Enhance one we've seen. In fact the unit pictured looks like the ST45SF-G with a new label.
Is that a new set of cables they are showing on that page ?
EDIT: Okay so these are on Silverstone's official site now. That is indeed a new cable set the PP05-E.
Yeah, the new SX600-G at CeBit is probably just the ST45SF-G with a new sticker for now.. still has v2.0 sticker on it as well.
Really? After setting up my rig in September I spent some time looking around for cables sets and never stumbled upon the PP05-E set... Oh well...Kinda new.. the PP05-E cable set has been out since around November.
Underwriters labs website doesn't yet list this in file E313296. Ecova also doesn't yet show certification for this PSU.
Laut Aussage des Herstellers wurde insbesondere darauf geachtet, die Betriebslautstärke durch den Lüfter weiter zu optimieren. Ein Preis wurde allerdings noch nicht angegeben.
