Do you know how much does it effect on that v-droop? Maybe I put it there after all. Am I right that I have to make it that double wire way and I can't use that MB side pin 20 for that? I believe that pin had some meaning before but not anymore these days, if I remember right?
I don't know exactly the v-droop effect, but it can't be that much if Silverstone guarantees ATX compliance without it.
I think pin 20 on MB side used to be -12V, useless now.
If you do a double wire, you can either splice it like I showed above, or crimp the two wires onto the pin, as I show below.
http://s225.photobucket.com/user/wisk23/slideshow/Double wire
