SidewinderX
- Mar 30, 2004
Hey everyone,
I've recently be struggling with some odd PC issues, and I'm starting to wonder if my primary HDD might be failing. I'll run through the cronology real quick, let me know if a) you think it's the HDD or b) it's something else.
Here's the current hardware setup: Intel E8400 @ stock, 4GB DDR2 ram, Corsair VX550 PSU, XFX 5850, main HDD WD 640GB AAKS, storage HDD WD 1TB Green.
Cronology-
Couple months ago - Upgraded from Vista to Win7, in-place upgrade (NOT a clean install)
1 month ago - Upgraded from ATi 3870 to ATi 5850. I had a couple problems with this upgrade, the worst of which was clearly from some driver issues. I finally got a clean set of drivers installed which seemed to solve most of the problem. I am worried that my PSU might not have enough juice for the 5850, even though the required PSU is 500W.
Last weekend - Started having all sorts of problems, everything hanging up, took forever to load/unload programs, stuff getting stuck for 20+ minutes before reacting, etc. I thought it was a bad permutation of the driver problem again, tried to reinstall the drivers, which took forever, and didn't end up fixing the problem. I think spent the rest of the weekend backing up my important stuff so I could do a clean install of Win7 and start from scratch.
This week - Clean install of Win7 went fine, started updating/installing programs, etc. Then yesterday I started setting things up, like firefox, windows media center, and songbird, and it took forever. For example, installing Media Browser for WMC took 35 minutes because it seemed to hang up for 10 minutes at a time, then get a little done, then hang up again, etc. Then I tried to shut down the computer and install some windows update and went to bed. I woke up this morning, 8 hours later, and the computer was still stuck on installing updated 1 of 6.
Since this is a new, clean install of win7, I'm at a loss. Which is why I'm here asking if this seems like a failing HDD. Any thoughts?
Cliffs:
1) Computer problems
2) Clean install of Win7.
3) Still have computer problems.
4) Failing HDD? Maybe weak PSU?
Cronology-
Cliffs:
