You can, but it's in a seperate area. Anyway, I can't seem to unlike teh 12V and ARGB 5V circuits in SIGNAL. I'll try Open RGB.I tried it and didn't quite like it. From what I could tell you couldn't assign colors to specific devices/zones. Just had to rely on the colors and patterns of the themes. I switched to OpenRGB instead and like that a lot more.
I found out that the reason is because Signal uses channels to assign devices. It's horrible, unless you have a true hub, like Corsair where you plug the hub into an internal USB connector. It that sense, each pin attachment is it's own channel. That's how Signal works. It's stupid really, because most people who are into lighting have multiple devices/strips.blocks/fans etc, and they use the MB header to send the signal to all of them using a "splitter hub" which is not the same thing as a "channel hub" like a Corsair ICU hub.I tried it and didn't quite like it. From what I could tell you couldn't assign colors to specific devices/zones. Just had to rely on the colors and patterns of the themes. I switched to OpenRGB instead and like that a lot more.
