vipz
- Apr 11, 2005
For something on the go it really needs to be smaller. A 100W card w/ a 150W brick that can also power the laptop via TB3/USB-C. The main unit needs to be the size of a Zotac EN1070 or smaller.
I get the idea and appeal of having a single PC, but I most certainly won't be able to put up with a 15W CPU or maybe even 45W.
What I would rather see is, instead of piping just the GPU out, why not have the laptop act as a dumb terminal + boot drive and run everything on the desktop CPU? Maybe even leverage VM tech to migrate a running instance from the laptop to the desktop so you don't have to reboot.
You plugged the Core in on the flight?!What card do you have in it?
That's way more than I thought an in-seat socket could handle.GTX 1080, no OC.
Man, I wonder how loud the fans had to be to be able to out-noise a friggin' airliner. It had to be fairly cool in the cabin as well. That really doesn't bode well for the prospect of eGPU-powered "mobile" gaming.
eGPU won't be mainstream for a while, it's too expensive right now. However, when GPU TDP gets lower, eGPU gets cheaper, then maybe.
But after dealing with the Razer Core, I decided to make the SideArmD wider to support 120mm fans.
Once can argue that removing the top fans altogether like the A4 is the way to go.
I actually wonder if there's any market at all for a cooling pedestal for the A4, or even a tempered glass display case w/ integrated bottom-up cooling + replacement side panels that are basically just the existing panels with a cutout that is as big as it can be.
Are the pannels any thicker?
So WC isn't a priority for the case? EK and EVGA are planning on releasing modular WC setups. The thought of having that in such a case, especially with a handle, is very appealing.
These are 1.5mm thick M1 panels meant for testing color and sandblasting.
The color and sandblasting texture are good.
I still need to test:
- scratch resistance
- 2-3mm panel thickness.
2-3mm panels will take some time because it requires a custom machine to be built.
AFAIK, the rule of thumb for punching holes repeatedly is that the diameter must be two times the thickness of the sheet metal. This is why Lian Li makes 3mm vents on 1.5mm thick aluminum.
Necere and I agreed on ventilation holes no larger than 3mm diameter (doesn't look good at larger diameters). To make 3mm holes on 2-3mm thick aluminum is tricky. Based on prior attempts with Lian Li, the wear & tear on tooling is very high (shorter tooling lifespan = higher cost per unit) and panel deformation was unacceptable.
Our factory plans to make a custom machine to do this, so it will take some time.
Necere has a new design that will have modular WC capability. So the SideArmD will be air cooling at a smaller volume, or WC (with add-on) at a bigger volume.
C'mon! Show us something! Don't be such a tease!![]()
When would this case become available?
If (a prototype of) this case becomes available soon I might just wait a little longer(not too long though, I'm still rocking Lynnfield on the system I plan to replace). Are we talking a couple of months? a year? multiple years?
- The sandblasted aluminium looks amazing. A grey finish like Phantek's "Anthracite Grey" or Apple's "Spacegrey" might look even better though ^^.
- The handle might not make sense when transporting the case for a longer distance in e.g a bag, but it looks very handy when moving the case inside your house (e.g from your desk to your TV).
- The handle breaks the lines of the case (like the sticking out parts of the Evolv), giving it a unique look while being functional at the same time :O.
- The A4 style GPU orientation makes a lot of sense for open air GPU coolers. Since I have an EVGA GPU with ACX 2.0+ this is very interesting for me.
- The NCASE really lacks support for exhaust fans. The fans in the top could make a big difference. Why not make the case a little longer to support at least 1 (back) 120mm exhaust fan? And why not rotate the PSU 90 degrees across the Z axis so the fan of the PSU faces the inside of the case, making the PSU fan acts as an exhaust fan...
- Maybe even put the PSU in the back top portion, fan facing down (the traditional location of ATX PSU's)? This would also make the PSU fan act as an exhaust fan and you could ditch the AC power cable running through the case. It would also justify the depth of the handle cutout.
There isn't room for a rear fan, period. Here's a pic of the back of the case (w360's original version) with an 80mm fan next to it:For me, the top fans are plenty already, so this is just curiosity on my part: I don't understand why there wouldn't be space for a rear 80mm+ exhaust fan. In your most recent "I-beam" GIFs, couldn't such a fan span both the graphics card and motherboard partitions of the I?
And responded there.Posted this feedback on SFF forum:
The top panel is actually not load bearing. Rather, the handle would bolt into a structural beam extending the length of the case:The handle is a must for me, otherwise there's no reason for me to get this case. Will the vented top panel be able to support the weight?
If we go with flexATX, we would likely provide it with the case and/or sell them separately.I would prefer SFX over FlexATX. A decent flexATX would be hard for me to get.
About 20mm.Nice idea with the bottom intake. How much gap between gpu and back of motherboard?
I agree, but that's space that's there anyway, and it would be occupied in a watercooled setup. An SFX PSU would also take up that space.No need for 3.5" hdd support.
Neither the SG05 nor the M1 has a suitable layout for a window though. The Sidearm also supports larger GPUs than either, and has better watercooling support than either with the extended bottom (though dual AIOs likely wouldn't be possible).At 11.5L, its bigger than my SG05 which is what I'm using for my portable LAN rig. (Of course the sidearmd will be replacing it)(Link if you haven't seen). With the wc attachment, its even bigger than the M1.
Probably around the same as the M1 or a little more, assuming full aluminum construction. The bulk of the weight would come from the components installed rather than the case.What's the estimated weight of the case?
Can't say at this point. That target was fairly speculative on w360's part anyway.Will this new design be able to meet the original proposed price of $120 - 160?
The non-extended version has no watercooling support. See my reply to NFSxperts above regarding 3.5" HDD support.If this case is designed to be travel friendly, I thin that water cooling support should be minimal without attachments. Space matters too much that all I really see it needing is a 120mm rad space for an AIO. I agree that 3.5" drive support is silly. We're starting to overlap too much with the M1.
GPU is still behind the motherboard, but facing the backside of the board, rather than the side of the case. The purpose of this is so instead of drawing air through the side panels, the components intake from inside the case. Fresh air is provided by the two bottom-mounted 120mm intake fans. The GPU orientation also has the advantage of requiring a shorter PCIe riser compared to the back-to-back design. Downside is the face of the GPU is mostly obscured, for those who care about that.
Yeah, the big handle cutout doesn't work with the change in layout.Mmh, I liked the looks of the cutout style handle better. I understand the new design might offer better airflow, but it doesn't break the "box" look that much.
It sounds like you mean to have the GPU draw air directly through a ventilated side panel, like the A4 does? The reason I'm not doing that is because it's impractical to filter the side vents, since dust filters are so restrictive and slim GPU fans aren't good at overcoming restriction. You can have direct access, or dust filters, but not both.Since I mostly use air cooled GPUs with non-reference coolers I care greatly about this. In fact, giving the GPU direct access to fresh air instead of dealing with tricky airflow mechanics is one of the main reasons SFF appeals to me.
I'm not quite sure what you mean by a "crossover" riser here. What advantage would it serve?As for the shorter PCIe raiser: wouldn't it be an option to have a crossover PCIe raiser, especialy when you plan to design one yourself?
The space is there, as I've shown above, it's just a matter of making the mounting work.Also, would it be an option to ditch the HDD cages in favor of an SFX power supply? I want to have a zero RPM capable PSU, and I don't care about hardrives.
I like the idea of allowing water cooling support for this case..... but I have one issue with it.
When traveling on a airplane you are limited to 3.4 oz of liquid on carry on bags. If you are traveling with a water cooled computer, you may have to drain the loop prior to travel unless you plan to put the computer in your checked bag.
For as many times as I've seen this brought up, not once have I ever heard of anyone having a problem getting through airport security with their watercooled PC. I think a factory sealed AIO is even less likely to be a problem than a custom loop with a res.I like the idea of allowing water cooling support for this case..... but I have one issue with it.
